EL Wire - Hot Pink
$7.30
SKU: DFR0185-HP
EL Wire lights up with high AC voltage, available in 10 colors. Uses include decoration, safety signs, and crafts. Specs: 3m length, hot pink color, 20-220V.
Purchase this product and earn 73 reward points, which are tied to VIP membership program. Learn More >
Electroluminecent wire, otherwise known as EL Wire, is a thin phosphor coated wire in a tube that lights up when you apply a high AC voltage to it. EL Wire typically needs anywhere between 20Vac to 220Vac, at a very low current. We have 10 different colors of EL Wire to choose from.
  • Indoor and outdoor advertisement, picture and logo, shop window, door, furniture, wall, roof, etc.
  • Car, boat and other vehicles decoration: inside and outside decoration, number display.
  • Safety sign and guidance: stair, passage, doorplate, temporary marks.
  • Toy, art and handcraft, sport article, garment, electrical appliance
  • Operating Voltage Range:20~220V
  • Optimum operating voltage:120V
  • Frequency range: 50-5000Hz
  • Optimum working frequency :1500-2000Hz
  • Direct capacitance:6nf/m(20℃,RH< 80%)
  • Glow Brightness:Voltage:120V,Frequency:200Hz~2000Hz:30cd/m2~126 cd/m2
  • Consumed Power:Voltage:120V,Frequency:200Hz~2000Hz:108mw/m~1032mw/m
  • Working Life:Voltage:100V,Frequency:400Hz,Normal Temperature and Humidity,Around 5000Hrs
  • Continous Working Temperature/Relative Humidity:-10℃~+60℃ ;RH< 90%
  • Storage Temperature/ Relative Humidity:-10℃~+60℃;RH< 65%
  • Diameter: 3mm(0.12")
  • Length: 3 meters(118")
  • Colour:hot pink
  • 3 meters (118") EL Wire x1
EL Wire - Hot Pink
