Hot Pink Electroluminescent (EL) Wire is a flexible decorative lighting cable built around a phosphor-coated core sealed inside a transparent protective tube. When driven by high-voltage alternating current, the luminous filament emits a smooth, continuous glow along the entire length. This illuminated wire provides an eye‑catching lighting solution for creative electronics, costume design, signage, and architectural accents. With a slim 3 mm diameter and a total length of 3 meters, this glowing cable integrates easily into compact spaces, curved surfaces, and artistic outlines while delivering uniform illumination and distinctive neon‑style visual effects.
Flexible Continuous Line Lighting
This electroluminescent lighting wire produces a smooth 360‑degree glow rather than discrete LED points, creating a seamless illuminated line suitable for outlines, patterns, and edge lighting. The phosphor-coated conductor inside the protective tube emits consistent brightness across the entire length, producing a soft neon-like effect. A 3 mm diameter profile allows the glowing cable to bend easily around corners, contours, and complex shapes, making the lighting strand particularly suitable for wearable electronics, artistic installations, decorative trims, and creative DIY lighting projects where flexibility and uniform illumination are essential.
Wide AC Driving Range for Lighting Inverters
This phosphor-based lighting strand operates with alternating current across a broad voltage and frequency range, supporting 20–220V AC operation with optimal performance around 120V and 1500–2000 Hz. Such compatibility enables integration with common EL wire drivers and lighting inverters used in decorative electronics. Stable electrical characteristics, including controlled capacitance and efficient power consumption per meter, support reliable brightness output while maintaining long operating life under normal environmental conditions, making this luminous cable suitable for extended decorative installations and creative illumination systems.
Bright hot‑pink illumination and flexible form factor enable wide creative use across visual design and decorative lighting projects. This glowing wire works well for accent outlines, animated costumes, illuminated signage, and artistic crafts. Integration into furniture edges, vehicle interiors, architectural accents, and safety guidance markings becomes straightforward thanks to the slim profile and uniform luminous output along the entire 3‑meter strand.
Electrical Parameters
Physical Dimensions
