EL Wire - Blue
$7.30
SKU: DFR0185-B
EL Wire is a phosphor-coated wire that illuminates with AC voltage. It comes in 10 colors and is used for decoration and safety signs, operating at 20-220V.
Purchase this product and earn 73 reward points, which are tied to VIP membership program. Learn More >
Electroluminescent (EL) Wire is a flexible lighting element consisting of a phosphor-coated copper core enclosed within a protective transparent sleeve. When energized with alternating current, this decorative illumination wire emits a smooth, continuous glow along the entire length rather than producing point-source light like LEDs. The glowing filament is widely used for artistic lighting, signage outlines, and creative installations thanks to its slim profile and uniform brightness. This 3 mm diameter luminous cable operates across a broad AC voltage and frequency range, enabling integration into decorative electronics, stage props, architectural accents, and customized lighting designs.
Uniform 360° Linear Glow
A phosphor-coated conductive core allows this electroluminescent lighting wire to generate a soft and evenly distributed glow across the full length of the cable. Unlike LED strips that produce segmented points of light, this glowing filament delivers a seamless luminous line ideal for outlining shapes, signage borders, costumes, or decorative objects. Consistent brightness along the 1‑meter length enhances visual continuity for artistic installations, display highlights, and edge illumination applications where smooth lighting effects are essential.
Flexible and Lightweight Decorative Lighting
A slender 3 mm diameter and lightweight construction enable this luminous decoration cable to bend easily around curves, frames, or structural edges. Such flexibility supports creative integration into clothing, craft projects, architectural accents, automotive interiors, and model displays. The protective outer tube shields the phosphor layer while maintaining the cable’s bendable structure, allowing designers and makers to route glowing lines through tight spaces or complex contours without sacrificing illumination continuity.
Wide Operating Voltage and Frequency Range
This EL illumination wire supports operation between 20 V and 220 V AC with a frequency range spanning 50 Hz to 5000 Hz. Optimal performance occurs near 120 V and 1500–2000 Hz, providing strong brightness while maintaining efficient power consumption. Such electrical tolerance allows compatibility with common EL inverters used in signage, decorative electronics, or stage lighting installations, making the luminous wire suitable for both experimental maker projects and professional decorative lighting setups.
Continuous glow, compact dimensions, and flexible routing make this electroluminescent cable suitable for visual design projects where traditional lighting sources cannot easily follow complex shapes. Typical applications include decorative vehicle accents, illuminated signage outlines, stage costumes, craft installations, and safety guidance markings in architectural environments.
  • Flexible electroluminescent wire with continuous 360° glow
  • Uniform lighting effect without segmented light points
  • Wide operating voltage range from 20V to 220V AC
  • Compatible with EL inverters operating between 50Hz and 5000Hz
  • Lightweight 3mm diameter cable suitable for creative installations
  • Ideal for decorative lighting, signage outlines, and artistic designs
  • Indoor and outdoor advertisement displays
  • Shop window, signage, and logo outlining
  • Automotive and boat interior or exterior decoration
  • Safety guidance lighting for stairs, passages, and doorplates
  • Art installations, crafts, toys, and costume decoration
  • Furniture, wall, roof, and architectural accent lighting
    Electrical Parameters
  • Operating Voltage Range:20~220V
  • Optimum operating voltage:120V
  • Frequency range: 50-5000Hz
  • Optimum working frequency :1500-2000Hz
  • Direct capacitance:6nf/m(20℃,RH< 80%)
  • Glow Brightness:Voltage:120V,Frequency:200Hz~2000Hz:30cd/m2~126 cd/m2
  • Consumed Power:Voltage:120V,Frequency:200Hz~2000Hz:108mw/m~1032mw/m
  • Working Life:Voltage:100V,Frequency:400Hz,Normal Temperature and Humidity,Around 5000Hrs
  • Continous Working Temperature/Relative Humidity:-10℃~+60℃ ;RH< 90%
  • Storage Temperature/ Relative Humidity:-10℃~+60℃;RH< 65%
  • Physical Parameters
  • Diameter: 3mm(0.12")
  • Length: 1 meters(39.4")
  • Colour: blue
  • 1 meters (39.4") EL Wire x1
  • Only 3 Left
    EL Wire - Blue
