Light Blue EL Wire (3m, 3mm) is a flexible electroluminescent lighting strip designed for decorative illumination and creative visual effects. This phosphor‑coated wire is sealed inside a transparent protective tube and emits a continuous glow when powered by high‑voltage AC signals. Unlike traditional LEDs, this luminous cable produces a smooth, uniform line of light without visible hotspots. Such electroluminescent lighting technology enables thin, bendable light accents suitable for signage, costume design, architectural outlines, and artistic installations where subtle neon‑like glow and flexible routing are required.
Flexible Continuous Glow Lighting
This electroluminescent lighting wire generates an even 360‑degree glow along the entire length, creating smooth light outlines ideal for decorative and artistic applications. The thin 3mm luminous cable bends easily around corners, edges, and irregular surfaces without breaking the lighting effect. Compared with rigid neon tubes or LED strips, this phosphor‑based illumination line offers greater flexibility and softer visual output, making the glowing wire especially suitable for costumes, wearable designs, creative crafts, vehicle decoration, and architectural accent lighting where consistent line lighting is essential.
Wide Voltage and Frequency Compatibility
This electroluminescent illumination cable operates across a broad voltage range from 20V to 220V AC and supports frequencies between 50Hz and 5000Hz. Optimal brightness performance occurs around 120V with frequencies between 1500Hz and 2000Hz, allowing stable glow intensity for different inverter configurations. Such electrical flexibility enables integration with various EL inverters used in signage, decorative lighting systems, and artistic displays. Efficient power consumption and stable capacitance characteristics further support reliable long‑duration operation across a wide range of lighting installations.
Decorative lighting installations, artistic displays, and safety guidance markings benefit from this luminous EL wire. Continuous glowing outlines enhance shop windows, interior decorations, vehicles, and creative crafts. Flexible electroluminescent strips also support costume design, stage props, and exhibition displays where lightweight glowing accents improve visual impact without bulky lighting hardware.
Electrical Parameters
Physical Parameters
