EL Wire - Orange
$7.30
SKU: DFR0185-O
EL Wire is a phosphor-coated wire that lights up with AC voltage. Available in 10 colors, it's used for decoration, signage, toys, and crafts.
Purchase this product and earn 73 reward points, which are tied to VIP membership program. Learn More >
Orange Electroluminescent (EL) Wire is a flexible decorative lighting cable that emits a continuous neon‑like glow when driven by a high‑frequency AC voltage. The luminous strand consists of a phosphor‑coated copper core enclosed in a transparent protective tube, allowing uniform illumination along the entire length. This electroluminescent lighting wire delivers vivid orange light while maintaining extremely low current consumption, making the glowing filament suitable for artistic installations, signage outlines, costume accents, and creative electronics projects. With a slim 3 mm diameter and a 1‑meter length, the luminous cord bends easily around shapes, frames, and surfaces while maintaining consistent brightness.
Flexible Linear Lighting for Creative Designs
This phosphor‑based lighting strand produces smooth and evenly distributed illumination along its entire length rather than at discrete points like traditional LEDs. The glowing cable structure allows smooth curves, outlines, and complex shapes to be formed around objects, clothing, architectural elements, or artistic displays. A slim 3 mm diameter enables installation in narrow spaces or intricate decorative patterns while maintaining visibility in low‑light environments. Such characteristics make this electroluminescent lighting solution especially effective for accent lighting, edge highlighting, and dynamic visual decoration.
Wide Operating Voltage and Stable Glow Performance
This EL lighting wire operates across a broad voltage range from 20V to 220V AC with low current consumption, providing flexible compatibility with common EL inverters and drivers. Optimal brightness occurs near 120V with operating frequencies between 1500Hz and 2000Hz, producing glow brightness from 30cd/m² to 126cd/m² depending on the driving conditions. Reliable phosphor excitation ensures consistent luminous output while maintaining low power usage between 108mW/m and 1032mW/m. With an approximate working life of 5000 hours under recommended conditions, this electroluminescent cable supports long‑term decorative and signaling applications.
This orange EL illumination wire enables distinctive lighting effects across decorative, artistic, and guidance applications. Flexible installation and uniform glow make the luminous cable suitable for outlining signage, decorating vehicles and interiors, highlighting architectural features, and creating wearable lighting designs. The glowing strand also supports safety indicators and visual guidance markings in low‑light environments where continuous linear illumination improves visibility and aesthetic appeal.
  • Flexible electroluminescent lighting wire with continuous linear glow
  • Bright orange illumination for decorative and signaling applications
  • Wide operating voltage range from 20V to 220V AC
  • Low power consumption with long operating life
  • Thin 3mm diameter suitable for detailed decorative layouts
  • Indoor and outdoor advertisement displays
  • Shop window and architectural decoration
  • Vehicle interior and exterior lighting accents
  • Safety guidance signs and temporary markings
  • Toys, wearable designs, and artistic crafts
  • Decorative lighting for furniture and interior spaces
    Electrical Parameters
  • Operating Voltage Range:20~220V
  • Optimum operating voltage:120V
  • Frequency range: 50-5000Hz
  • Optimum working frequency :1500-2000Hz
  • Direct capacitance:6nf/m(20℃,RH< 80%)
  • Glow Brightness:Voltage:120V,Frequency:200Hz~2000Hz:30cd/m2~126 cd/m2
  • Consumed Power:Voltage:120V,Frequency:200Hz~2000Hz:108mw/m~1032mw/m
  • Working Life:Voltage:100V,Frequency:400Hz,Normal Temperature and Humidity,Around 5000Hrs
  • Continous Working Temperature/Relative Humidity:-10℃~+60℃ ;RH< 90%
  • Storage Temperature/ Relative Humidity:-10℃~+60℃;RH< 65%
  • Physical Parameters
  • Diameter: 3mm(0.12")
  • Length: 1 meters(39.4")
  • Colour: orange
  • 1 meters(39.4") EL Wire x1
  • Only 14 Left
    EL Wire - Orange
