10 Segment LED Bar Graph - Red
$1.50
SKU: FIT0188
Compact 10-segment red LED bar graph suitable for prototyping or products. Applications include audio equipment, panels, displays. Low power consumption.
Purchase this product and earn 15 reward points, which are tied to VIP membership program. Learn More >
10 Segment LED Bar Graph – Red provides a compact visual indicator for analog levels, signal strength, and system status displays. This linear LED indicator integrates ten individual super‑bright red LEDs within a single industrial‑standard package, enabling clear multi‑level visualization without complex display modules. The segmented light array simplifies hardware design for embedded electronics, measurement instruments, and interactive prototypes. With straightforward pin connections and low power consumption, this bar‑style LED display component serves as a practical solution for engineers, makers, and educational electronics projects requiring simple yet effective level indication.
Compact Multi‑Segment Visual Indicator
This 10‑segment LED indicator integrates ten discrete red LEDs into a single compact bar‑style package, forming a clean linear display suitable for real‑time level monitoring. Each segment can be driven independently, allowing flexible visualization of analog values, signal strength, or system states. Compared with discrete LED arrangements, this integrated light bar reduces PCB complexity and wiring requirements while maintaining consistent spacing and brightness across segments. The industrial‑standard footprint also simplifies installation into both prototype boards and finished electronic devices.
Simple Integration for Prototyping and Embedded Displays
This LED bar display module offers straightforward electrical interfacing for microcontroller projects, measurement equipment, and control panels. Individual segment control allows designers to create intuitive visual feedback for voltage levels, audio intensity, battery charge states, or other analog measurements. Low power consumption and categorized luminous intensity support reliable and efficient operation across a wide range of electronics designs. As a result, this segmented LED display component fits equally well in rapid prototyping environments and permanent product installations.
Clear segmented illumination makes this linear LED display suitable for dashboards, audio meters, and embedded instrumentation panels. Applications commonly include signal strength visualization, digital readout indicators, system status displays, and creative lighting installations. Reliable brightness, compact packaging, and simple driving circuitry allow this LED bar graph to function effectively in both educational electronics builds and professional device interfaces.
  • 10 integrated super bright red LED segments
  • Compact industrial‑standard bar graph package
  • Independent control of each LED segment
  • Low power consumption design
  • Consistent luminous intensity across segments
  • Suitable for prototyping and embedded product integration
  • Audio equipment level indicators
  • Instrument panels
  • Digital readout displays
  • Signal strength indicators
  • Power status displays
  • Interactive or artistic lighting displays
    Electrical Parameters
  • Forward Current (Per Segment): 25mA
  • Max Reverse Voltage: 5v
  • General Characteristics
  • 10 segment bar
  • Color: Super Bright Red
  • Industrial standard size
  • Categorized for luminous intensity
  • 10 Segment LED Bar Graph - Red x1
