Fermion: LSM303 Tilt Compensated Compass (Breakout, Discontinued)
SKU: SEN0079
Discontinued
The LSM303DLH Tilt‑Compensated Compass Breakout Board integrates a three‑axis accelerometer and a three‑axis magnetic field sensor into a compact motion‑sensing module for orientation and navigation applications. Built around the LSM303DLH chip, this 6‑axis sensing board delivers high‑resolution motion and heading data through an I2C interface, enabling embedded systems to calculate accurate tilt‑compensated compass readings. This combined accelerometer‑magnetometer module simplifies the process of obtaining directional awareness, motion sensing, and spatial orientation data for embedded platforms such as Arduino, robotics controllers, and custom microcontroller systems.
Integrated 6‑Axis Motion and Magnetic Sensing
This compact orientation sensing board combines a triple‑axis accelerometer with a triple‑axis magnetometer in a single hardware platform. The accelerometer measures linear acceleration and tilt, while the magnetic sensor detects the surrounding geomagnetic field. By merging both datasets, this digital compass module enables tilt‑compensated heading calculations that remain accurate even when the sensor board is angled. Such integrated sensing capability supports applications requiring stable directional data, including navigation systems, motion analysis devices, and smart embedded electronics that rely on spatial awareness.
Flexible Motion Detection and Intelligent Interrupt Functions
Advanced motion detection features allow this inertial sensing module to monitor dynamic environmental changes and trigger programmable responses. Built‑in interrupt generators support functions such as free‑fall detection and motion activation, while embedded orientation logic enables six‑direction (6D) position recognition. These capabilities allow the motion tracking board to automatically detect events such as sudden impacts, device orientation changes, or inactivity. Integrated sleep‑to‑wakeup functionality further improves power efficiency in portable electronics and handheld devices by activating the accelerometer only when movement occurs.
High‑Resolution Data and I2C Interface Integration
Equipped with a 16‑bit data output and a standard I2C communication interface, this digital motion and compass sensor delivers precise measurement data while remaining easy to integrate into embedded control systems. Adjustable measurement ranges allow acceleration detection at ±2 g, ±4 g, or ±8 g, along with magnetic field measurement from ±1.3 to ±8,1 gauss. Such configurable sensing parameters make the module suitable for robotics navigation, interactive electronics, and sensor‑driven control systems requiring accurate real‑time orientation feedback.
This tilt‑compensated compass module enables developers to add reliable heading detection, motion sensing, and spatial awareness to embedded electronics projects. Applications range from robotic navigation and handheld device orientation detection to motion‑activated electronics, vibration monitoring, and interactive gaming systems. Compact size and integrated multi‑axis sensing make this accelerometer‑magnetometer breakout board an effective solution for motion analysis, navigation experiments, and sensor‑based embedded development.
  • Integrated 3‑axis accelerometer and 3‑axis magnetometer (LSM303DLH)
  • Supports tilt‑compensated compass calculations
  • Selectable acceleration ranges: ±2 g, ±4 g, ±8 g
  • Magnetic field measurement range from ±1.3 to ±8,1 gauss
  • 16‑bit high‑resolution sensor data output
  • I2C serial communication interface
  • Two programmable interrupt generators for motion and free‑fall detection
  • Embedded self‑test function
  • Accelerometer sleep‑to‑wakeup capability
  • 6D orientation detection support
  • Compensated compassing
  • Map rotation
  • Position detection
  • Motion-activated functions
  • Free-fall detection
  • Intelligent power-saving for handheld devices
  • Display orientation
  • Gaming and virtual reality input devices
  • Impact recognition and logging
  • Vibration monitoring and compensation
    Basic Parameters
  • Power supply: 3.6~8V DC
  • Chip: LSM303DLH
  • ±1.3 to ±8,1 gauss magnetic field full-scale
  • ±2 g/±4 g/±8 g dynamically selectable fullscale
  • 16-bit data out
  • I2C serial interface
  • 2 independent programmable interrupt generators for free-fall and motion detection
  • Embedded self-test
  • Accelerometer sleep-to-wakeup function
  • Physical Dimensions
  • Dimensions: 20.5mmx20.5mm(0.8x0.8'')
  • Weight: 1g
  • LSM303 breakout board x1
