D65mm Rubber Wheel Pair - Blue (Without Shaft)
$6.95
SKU: FIT0199-B
Rubber wheels for small robots with soft tread for traction. Requires axis adapter for motor mounting. Available in red, blue, silver. Random tire pattern.
Purchase this product and earn 70 reward points, which are tied to VIP membership program. Learn More >
These are typical rubber wheels for small robot mobile platforms. The tire is soft black rubber with light tread for added traction in rugged terrain.
An axis adapter is needed which bolts to the back of the hub and mounts to a motor. this adapter(FIT0198) can mount to our Micro DC Geared Motor with Back Shaft(FIT0016).
These motors are commonly used in our 4WD and 2WD platforms like Turtle (ROB0005), Pirate (ROB0003), Baron(ROB0025) ....
We've prepared 3 different colors for you to choose: Red/Blue/Silver. Enjoy!
You will need our Motor Adapter to fit this into Gear motor.
Note:The material and pattern of the tire will be shipped randomly.
  • Tire matrerial: Rubber
  • Outside diameter: 65mm(2.56")
  • Tire width: 26mm(1.02")
  • Hub color: Blue
  • Rubber wheel(2 Units)
