DFRduino Mega2560 (Arduino Mega 2560 R3 Compatible)
$22.90
SKU: DFR0191
The new microcontroller features improved power supply, wider voltage range, and works with a 3.7V battery. It includes 54 digital I/O, 16 analog inputs, and 256KB flash.
Purchase this product and earn 229 reward points, which are tied to VIP membership program. Learn More >
The new version of DFRduino Mega2560 has improved the VIN power supply circuit by changing the easily overheat LDO to DC-DC circuit for ensuring safety and reliability in long-term use. In addition to optimizing the overheating issue, it offers a wider input voltage range. What’s more, DFRduino Mega2560 can work steadily even when only powered by a 3.7V lithium battery.
DFRduino Mega2560 is an ATmega2560-based microcontroller that provides full compatibility with "Arduino MEGA2560“. It features 54 digital I/O ports, 16 analog signal input ports, 4 UARTs(hardware serial ports), and a 16MHz crystal oscillator. The board comes with a bootloader that enables users to download programs directly via a USB. You can simply power it with a USB cable or a standard adapter or use a battery as external power. Mega 2560 has 256KB FLASH, two times of Mega1280, which could offer a larger create space for your projects.
  • Controller Model: ATmega2560
  • Operating Voltage: 5V
  • Input Voltage(VIN): 3-16V(20V max)
  • Digital I/O Pins: 54 (of which 15 provide PWM output)
  • Analog Inputs: 16 I/O
  • FLASH: 256 KB (of which 4 KB is used by the bootloader)
  • SRAM: 8KB
  • EEPROM: 4KB
  • Frequency: 16MHz
  • DFRduino Mega2560 Microcontroller x1
  • Certifications
    How to Make a Bluetooth Music Player
    Blog How to Make a Bluetooth Music Player
    Jul 06, 2018
    DFRobot Arduino-Compatible Microcontrollers Selection Guide
    Blog DFRobot Arduino-Compatible Microcontrollers Selection Guide
    Jul 30, 2020
    RiverTrue
    Jan 23, 2025
    INTEGRATING ARDUINO INTO PLC SYSTEM
    Projects INTEGRATING ARDUINO INTO PLC SYSTEM
    tuenhidiy
    May 06, 2020
    Jennifer.Roman Sep 09, 2025
    excellent quality, will order again.
