Dual-channel DC motor driver for robotics and embedded motion control. A dual H-bridge motor driver based on L298N, designed for controlling two brushed DC motors with direction and speed regulation. Compatible with Arduino, ESP32, Raspberry Pi and other microcontroller platforms.
Dual motor control system
Supports independent control of two brushed DC motors with direction control and PWM speed regulation, suitable for basic robotic motion systems.
Stable L298N H-bridge driver
Built on the L298N dual H-bridge architecture, providing up to 2A output per channel with integrated protection diodes for safe motor operation.
Practical power handling range
Supports a wide motor supply range from 4.8V to 46V, making it compatible with both low-voltage and higher-voltage DC motor setups in prototyping environments.
Thermal and load reliability
Equipped with an enhanced heatsink design to improve thermal performance under continuous operation and medium-load conditions.
Simple and robust hardware interface
Uses screw terminal connectors with clearly labeled control and motor outputs, designed for fast wiring in prototyping and educational setups.
Figure: Comparison with alternative drivers
Jun 08, 2025
What should I say about - I love it. It's like Plug & Play and quality is very good.
