The DFRduino Nano USB Microcontroller V3.1 (ATMega 328) is a breadboard ready version of the " Arduino mini" with integrated USB. The "Arduino Nano" has everything that the Diecimila has (electronically) with more analog input pins and an on-board +5V AREF jumper. The "Arduino Nano" automatically senses and switches to the higher power supply, so there is no need for a power select jumper.
The nano's pin layout works well with the Mini or the Basic Stamp (TX, RX, ATN, GND on one top, power and ground on the other). The DFRobot DFRduino Nano USB Microcontroller V3.1 (ATMega 328) can be powered via the mini-B USB connection, 6-20V unregulated external power supply (pin 30), or 5V regulated external power supply (pin 27). The power source is automatically selected to the highest voltage source.
Dec 13, 2025
For hobby projects and budget prototyping, the DFRduino Nano punches above its price point and gives you the full Nano experience at a fraction of the cost — just be ready for some variability in quality and driver setup....
Nov 26, 2021
All ok, description write in the good way
Aug 26, 2021
First looks have a bit problemn for uploading file. After googling, its ok.
