Crimp Pin for Female Housing Pin (2.54mm Pitch) provides a reliable metal contact solution for building custom jumper cables and connector assemblies in electronics prototyping and embedded development. Designed for standard 2.54mm (0.1") pitch female housings, this connector crimp terminal mates securely with common 0.1" male header pins used across development boards, sensors, and expansion shields. The precision‑formed metal terminal enables stable electrical contact and consistent mechanical retention once crimped to wires and inserted into compatible housings, making the connector pin suitable for prototyping cables, harness fabrication, and modular electronics wiring projects.
Reliable Electrical and Mechanical Connection
This 2.54mm crimp terminal is engineered to create dependable electrical contact between wire conductors and standard header pins. When properly crimped using an appropriate crimping tool, the metal contact forms a firm grip on both conductor and insulation layers. The result is a durable connection that resists loosening during repeated plug‑and‑unplug cycles, supporting stable signal transmission in electronics prototypes, sensor interfaces, and breadboard-compatible wiring assemblies.
Ideal for Custom Cable and Connector Fabrication
The 2.54mm female housing crimp contact enables flexible cable design for robotics, embedded systems, and development platforms. Combined with compatible plastic housings, the terminal allows builders to assemble custom jumper wires tailored to specific wiring layouts or connector sizes. This connector component supports modular wiring harnesses, sensor extension cables, and organized signal routing in prototyping environments where standard pre‑made cables may not match project requirements.
Typical use cases include custom jumper wire creation, robotics wiring harnesses, sensor connection leads, and electronics prototyping cable assemblies. The crimp contact integrates with 2.54mm female housings to produce connector cables compatible with breadboards, development boards, and standard header‑based expansion modules.
