Powerline Ethernet Adapter (200M) -2 Units (Discontinued)
SKU: TEL0057
Discontinued
Note: The Powerline Ethernet Adapter is discontinued now
If you need other power adapter, please click here.
The Powerline Ethernet Adapter(STP-PLC200PT/STP-PLC200PP-A) is a device which can deliver a fast Internet signal to the farthest corners of your home.It operate by sending a modulated carrier signal over your regular AC wiring. You can route your Internet connection around your house over your regular electrical power lines.It really works. It's fast and it doesn't disrupt your electrical system. Even better, it requires zero technical skill. The devices conform to the HomePlug AV specification and deliver a peak data rate of 200Mbps at the physical layer and about 80Mbps at the MAC layer.It is very convenient to use it and widely used in houses, offices,hotels and so on.In addition,the Powerline Ethernet Adapter(STP-PLC200PP-A)can provide power to set-top boxes, home gateways, network cameras and other devices.
Notice: If you haven't HomePlug AV specification ,you should use a pair of Powerline Ethernet Adapters to connect to the internet.
Specification for STP-PLC200PT
  • Bandwidth:200Mbps
  • Input power: AC110-250V 50Hz/60Hz
  • Ethernet interface: 1 port 100/10M Based-T
  • Comm standard:Homeplug AV
  • Comm agreement: IEEE 802.3,IEEE 802.3x,IEEE 802.3u,TDMA, CSMA/CA
  • Electrical safety: Two boards separate strong electric and weak electric
  • Encryption technology: 128bit AES
  • Environment temperature:-5~60℃
  • Size:47mm x 90mm x 77mm(1.85"x3.54"x3.03")
  • Weight:150g
Specification for STP-PLC200PP-A
  • Bandwidth: 200Mbps
  • Input power: AC80-260V 50Hz/60Hz
  • Output power: 12V/1.5A DC
  • Comm standard: Homeplug AV
  • Comm argeement: IEEE 802.3,IEEE 802.3x,IEEE 802.3u,TDMA, CSMA/CA
  • Encryption technology:128bit AES
  • Environment temperature:-5~40℃
  • Size:47x90x77mm(1.85"x3.54"x3.03")
  • Weight:150g
  • Powerline Ethernet Adapter  STP-PLC200PT (x1)
  • Powerline Ethernet Adapter  STP-PLC200PP-A (x1)
