DFRobot 12" 10-wire female-to-female ribbon jumper cable provides a simple and organized way to connect development boards, sensor modules, and breadboard circuits during prototyping. Each cable strip contains ten color-coded conductors arranged in ribbon form, helping maintain clean wiring layouts while reducing connection mistakes. The multicolor jumper ribbon supports quick circuit assembly in electronics labs, robotics builds, and rapid hardware testing environments. Individual wires can be separated when single connections are required, allowing flexible use across breadboards, expansion shields, and embedded development platforms.
Note: 0.1" housing pins are not included.
10-Color Ribbon Layout for Organized Wiring
This multicolor jumper ribbon groups ten wires into a compact strip, simplifying cable management in prototype assemblies. Distinct color coding helps quickly identify signal paths and reduces wiring errors during circuit debugging. The ribbon arrangement also keeps connections tidy on crowded breadboards or controller shields, making the cable assembly especially useful for electronics experimentation, robotics wiring harnesses, and structured prototyping setups where multiple signal lines must remain visually organized.
Separable Conductors for Flexible Use
Each conductor within the ribbon structure can be easily peeled away for individual use. This design allows the jumper assembly to function both as a grouped ribbon cable or as separate single-line jumpers depending on project needs. The detachable structure makes the wiring accessory suitable for breadboard signal routing, module-to-board interconnection, or quick modifications during hardware debugging and iterative development.
Pre-Crimped Female Headers for Rapid Prototyping
Every conductor arrives pre-terminated with female headers on both ends, eliminating manual crimping work and enabling immediate use in development setups. The dual female connectors fit standard 0.1-inch pin headers commonly found on development boards, breakout modules, and breadboards. This ready-to-use wiring solution accelerates prototyping workflows in electronics labs, engineering classrooms, and maker workshops.
Common uses include breadboard prototyping, sensor module wiring, controller expansion testing, robotics electronics assembly, and educational electronics experiments. The separable ribbon jumper set serves as a convenient wiring accessory for makers, engineers, and STEM learning environments that require fast, repeatable signal connections during hardware development.
Oct 15, 2021
Great Product
