Desoldering Pump
$6.90
SKU: FIT0216
  • $6.60 5+ items
  • $6.20 10+ items
  • $5.70 50+ items
Compact spring-loaded desoldering pump made of ABS plastic, with 35 cm-Hg suction and no air leakage. Features comfortable grip and easy solder clearance.
This is a compact,spring loaded desoldering pump. It is a very useful tool for desoldering components from PCBs. ProsKit DP-366D Desoldering Pump with suction capability 35 cm-Hg. It's made of ABS plastic.
  • Piston with double oil seals: no air leakage guarantee
  • Handle with soft foam provides comfortable, non-slip operation
  • Compact and lightweight design.
  • Anti-rust spring
  • Spring loaded piston
  • Overall Length: 8-1/4"
  • Quick and easy solder residue clearance
  • Material: ABS plastic
  • Suction capability: 35cm-Hg
  • Size: 30x30x205mm(1.18"x1.18"x8.07")
  • Weight: 85g
  • Desoldering pump x1
Only 13 Left
Desoldering Pump
