Compact spring-loaded desoldering pump made of ABS plastic, with 35 cm-Hg suction and no air leakage. Features comfortable grip and easy solder clearance.
Purchase this product and earn 69 reward points, which are tied to VIP membership program.
Learn More >
This is a compact,spring loaded desoldering pump. It is a very useful tool for desoldering components from PCBs. ProsKit DP-366D Desoldering Pump with suction capability 35 cm-Hg. It's made of ABS plastic.
Piston with double oil seals: no air leakage guarantee
Handle with soft foam provides comfortable, non-slip operation
