This is a high-quality, easy to use 28 pin ZIF socket (Zero Insertion Force) that is 0.3" wide.
This socket is typically used in circuits where a chip will be exchanged many times. For example in a circuit used to flash firmware or a bootloader onto an Arduino.
Uses high conductivity terminals to create solid connections.
