EL Wire 2xAA Pocket Inverter
$4.20
SKU: FIT0229
  • $4.10 2+ items
  • $4.00 5+ items
  • $3.90 10+ items
An inverter for EL wire powered by 2 AA batteries, lasting 8-10 hours. Features on/off and blink modes, a belt clip, and a JST connector. Batteries not included.
Purchase this product and earn 42 reward points, which are tied to VIP membership program. Learn More >
This inverter is the most common way to power EL wire because they tend to be cheap and batteries generally last a long time.
2 AA Batteries can power an 2.5m strand of EL Wire for about 8-10 hours.We recomend you use the rechargeable batteries, though the operating time might be less.
It comes with a constant on/off switch and blink mode. Takes 2xAA Battery (not included).
The battery pack comes with a belt clip you can use that to attach to clothing, hats, etc...
Battery pack comes with a 2.5mm (0.1") pitch female JST connector.
NOTE:We recomend to remove the batteries from the inverter when not in use, because on occasion it is hard to tell if a battery pack is still “On”.
  • Size: 90mm x 32mm x 20mm (3.54x1.26x0.79")
  • input voltage: 3v
  • FIT0229 (2xAA Battery Not Included) x1
Only 18 Left
