BarePaint - Conductive Paint Pens (10ml) (Discontinued)
SKU: FIT0264
Discontinued
Note: BarePaint - Conductive Paint Pens is discontinued now.
Bare Paint is just like any other water-based paint... except that it's electrically conductive! This means that you can actually paint wires onto things like models, clothes, furniture, walls, almost anything you can think of. Standard acrylic or water-based paints can even be used alongside Bare Paint to act as insulation or to create multi-layer circuitry!
You can apply Bare Paint like any other water-based paint.This conductive paint pen is easy to carry and draw a picture. Whenever,with it you can play your inspiration.It's important to note that as Bare Paint dries the conductivity increases (and will continue to increase to a certain extent even after the Paint "feels" dry), so if your project requires calibration, let the Paint dry completely before testing it.
Note: Bare Paint is not meant for use on skin!It is not waterproof, but depending on what your application is you can paint over it with a waterproof paint or varnish. On the bright side this does make for easy cleanup.
  • Water-based, nontoxic and dries at room temperature.
  • Bare Paint can be applied to a wide variety of materials, including (but certainly not limited to) paper, cardboard vellum, wood, metal, plaster, some rubbers, plastics and many textile.
  • Soap and warm water will take Bare Paint off of most surfaces.
  • Can last years if treated properly and kept dry.
  • BarePaint-Conductive Paint Pens(10ml) x1
