AL Heat Sink (With adhesive tape) - 28*28*11mm
$2.50
SKU: FIT0223
  • $2.40 2+ items
  • $2.30 5+ items
  • $2.10 10+ items
High-quality aluminum heat sink with strong 3M thermal adhesive tape, suitable for stepper motors and driver boards. Silvery color, weighs 13g, size 28x28x11mm.
This is a high quality AL Heat Sink(With adhesive tape).There is a high quality of U.S. origin 3M-8810 thermal adhesive tape on the back of the heatsink. So you needn't coat a layer of heat conduction glue on the heatsink,Just remove the blue protective film on the thermal adhesive tap and then stick in the desired chip parts.Viscidity is very strong.
Notice: Make sure the surface of the component is clean before sticking the heatsink.
  • This heat sink can be used with stepper motors, motor driver board and so on.
  • Material:Aluminum
  • Color:Silvery
  • Weight:13g
  • Size:28*28*11mm (±2mm)
  • AL Heat Sink(With adhesive tape) x1
