Hybrid Stepper Motor for 3D Printer (3.5kg)
$6.80
SKU: FIT0278
High-quality 2-phase hybrid stepper motor with 3.5kg torque, ideal for CNC machines and 3D printers. Features a 4-pin JST connector and 50cm cable.
Purchase this product and earn 68 reward points, which are tied to VIP membership program. Learn More >
This is a commonly used stepper motor, model 42BYGH40-1.8-23A. It provides precise motion control with a step angle of 1.8°, supports microstepping drives, and ensures smooth movement and accurate positioning to meet high-resolution motion requirements. With strong and reliable power, it delivers a holding torque of up to 3.6 kg·cm, providing sufficient load capacity and ensuring stable, nonloststep operation over long periods. The motor features a compact and robust design, with a metal housing and standard mounting holes (4×M3), making it durable and easy to install. It operates with low power consumption and high efficiency, rated at 3.5V and 1.7A/phase, balancing power output with energy efficiency.
Widely applicable in 3D printers, robotics, automation equipment, small conveyor platforms, and other R&D projects, it offers stable performance and is ready to use upon installation.
Note: Before selecting the motor, please verify its rated torque, dimensions, mounting specifications, and other parameters to ensure the appropriate model is chosen.
  • 3D Printers: Driving X/Y/Z axes for highprecision printing
  • Robotics Projects: Joint actuation, wheeled chassis control, positioning execution
  • Automation Equipment: Small CNC machines, feeding mechanisms, instrument positioning
  • Intelligent Mobile Platforms: Inspection vehicles, carrying platforms, demonstration models
  • Step Angle: 1.8° per step
  • Rated Current: 1.7 A/phase
  • Number of Phases: 2
  • Phase Resistance: 1.8 Ω ±10% (20°C)
  • Phase Inductance: 3.6 mH ±20% (1 kHz, 1 V rms)
  • Holding Torque: 350 mN·m Min (two phase energized)
  • Rotor Inertia: 57 g·cm²
  • Motor Weight: 283 g Ref
  • Insulation Resistance: 100 MΩ Min (DC 500 V)
  • Insulation Class: B (130°C)
  • Connector Type: JST XH 2.54 x 4P
  • Mounting Hole Specification: 4 x M3
  • Lifespan: 6000h
  • Hybrid Stepper Motor for 3D Printer (3.5kg) x1
  • Review
    kyusung. Nov 15, 2020
    I am satisfied with the quality, price and delivery.
    Only 14 Left
