XH2.54 Connector Kit (2.5mm, 0.1")
$5.50
SKU: FIT0255
The kit includes XH housings, shrouded headers, and crimp contacts. It supports up to 3A current, 250V, and operates between -25℃ to +85℃.
Purchase this product and earn 55 reward points, which are tied to VIP membership program. Learn More >
This kit includes XH-2, XH-3, and XH-4 housing (20 units each), through-hole type shrouded header (20 units each), and crimp contact (100 units).
  • Current rating:3A AC,DC (AWG #22)
  • Voltage rating:250V AC,DC
  • Temperature range:-25℃ to +85℃(including temperature rise in applying electrical current)
  • Contact resistance: Initial value/10m Ω max.
  • After environmental testing/20m Ω max.
  • Insulation resistance:1000M Ω min.
  • Withstanding voltage:1000V AC/minute
  • Applicable wire:AWG#30~#22
  • Applicable PC board thickness:1.6mm (0.06")
  • 2.5mm (0.1") XH-2 housing  x20
  • 2.5mm (0.1") XH-3 housing  x20
  • 2.5mm (0.1") XH-4 housing  x20
  • 2.5mm (0.1") B2B-XH-Athrough-hole type shrouded header  x20
  •  2.5mm (0.1") B3B-XH-Athrough-hole type shrouded header  x20
  • 2.5mm (0.1") B4B-XH-Athrough-hole type shrouded header  x20
  • crimp contact x100
  • Two-sided Compartment Parts Box  x1
MAREO.JACOBS Nov 16, 2021
This kit worked great to comlete my project. Would be great if it came with a crimper.
