DFRduino Leonardo with Xbee Socket (Arduino Leonardo Compatible)
$15.90
SKU: DFR0221
  • $15.60 2+ items
  • $15.10 5+ items
  • $14.60 10+ items
Leonardo with Xbee Socket is Arduino-compatible, featuring ATmega32u4, USB-HID support, Xbee socket, and sensor extension pins. Requires Arduino IDE 1.0.1+.
Featured in Make: The Maker’s Guide to Boards, DFRobot Leonardo with Xbee Socket is compatible with  Arduino Leonardo. The "Arduino Leonardo" is based on the ATmega32u4 chip. It is the latest addition to the Arduino family. Compared with the earlier Arduino controllers, using the ATmega32U4 as its sole microcontroller, allows the Leonardo to be cheaper and simpler to use. Also, because the 32U4 is handling the USB directly, code libraries allow the board to emulate a computer keyboard, mouse, and more using the USB-HID protocol!
DFRobot Leonardo image courtesy of Make Magazine
Based on the "Arduino Leonardo", this one from DFRobot equips an XBee socket and 3 sensor extension pins for your application. The Xbee is a commonly used wireless communication module with 2.4G Zigbee,900Mhz version, etc. The socket makes it possible for you to extend the XBee or XBee form factor wifi, Bluetooth, and RF modules for your Arduino directly. However, the D14~D16 extension pins with power supply maximize the use of your ATmega32u4 microcontroller. They support the digital sensors and modules from DFRobot directly.
Notice: This board is only supported in the latest Arduino IDE 1.0.1 or later version, so you must update the IDE.
  • Input Voltage (recommended): 7-12V
  • Input Voltage (limits): 6-12V
  • Microcontroller: ATmega32u4
  • Operating Voltage: 5V
  • Interface: Micro USB
  • Compatible with Arduino Uno R3 series pin mapping
  • Directly support Xbee and XBee form factor wifi, Bluetooth, and RF modules
  • Extend D14~D16 digital pins with 5v power supply
  • Clock Speed 16 MHz
  • Size: 70x55x14mm (2.76x2.17x0.55")
  • Microcontroller Specification
    • Digital I/O Pins: 20
    • PWM Channels: 7
    • Analog Input Channels: 12
    • DC Current per I/O Pin: 40 mA
    • DC Current for 3.3V Pin: 800 mA
    • Flash Memory 32 KB (ATmega32u4) of which 4 KB used by the bootloader
    • SRAM: 2.5 KB (ATmega32u4)
    • EEPROM: 1 KB (ATmega32u4)
  • DFRobot Leonardo & Xbee R3     x1
LattePanda Tutorial: Control the Screen Brightness Automatically
Blog LattePanda Tutorial: Control the Screen Brightness Automatically
Apr 03, 2018
DFRobot Arduino-Compatible Microcontrollers Selection Guide
Blog DFRobot Arduino-Compatible Microcontrollers Selection Guide
Jul 30, 2020
