DF15RSMG 360 Degree Servo Motor
$11.50
SKU: SER0035
A 360-degree servo for robotic applications, controllable for direction and speed but not precise position. Features include durable shells, copper gears, and low noise.
Purchase this product and earn 115 reward points, which are tied to VIP membership program. Learn More >
Note: This 360-degree servo DOES NOT offer exact position control of the shaft. It more behaves like a DC motor. Only direction and speed can be controlled. For servos that can be fixed at a certain position, please check out these 180-degree servos.
DF15RSMG is a powerful 360-degree servo motor from DFRobot, which is mainly designed for robotic applications requiring servos with large torque and high stability, like 360-degrees robot joints, mobile robots, etc.
The following features make it an excellent choice for robotic projects:
  • Two sets of servo shells. One is a standard shell with four M4 mounting holes, and the other equips with durable double-bearings which are especially suitable for the application of the robot arm or the joints. Both shells are thickened to make it stable enough for the motion system.
  • Copper & steel gear instead of plastic one.
  • Small jitters and low noise. Lock function for the pulse to reduce MCU consumption. PWM signal for direction control.
  • Fittings like servo horn, screws, etc., are all included, convenient for project building.
  • Easy to use with the Arduino servo. h library
  • Cable Definition
  • Brown - GND
  • Red - VCC
  • Orange - PWM Signal Input
    Mechanical Parameters
    • Rotation Angle Range: 360°
    • No-load Speed: 60°/0.16s @7.2v
    • Stall Torque: 15kg.cm(7.2v)
    • Size: 40x40x20mm (1.57x1.57x0.79")
    • Weight: 60g
    Electrical Parameters
    • Working Voltage: 5-7.2v
    • Stall current:2.5A(@7.2V - Limit test)
    • PWM Voltage:3V-5V
    • Range of PWM positive pulse width: 500us-2500us
    • DF15RSMG Servo x1
    • Servo Shell x2
    • Fitting Package x1
