Encoder Adapter
$3.50
SKU: FIT0324
This adapter enhances compatibility for 12V DC motors, integrating pull-up resistors for voltage control. Includes adapter, cable; compatible with open collector output.
Purchase this product and earn 35 reward points, which are tied to VIP membership program. Learn More >
This adapter is especially designed for DFRobot 12V DC Motors, adding the compatibility factor for those products without customized connectors or external power supplies.
This adapter integrates an external pull-up resistor, which raises the output voltage when the transistor is turned off. This board has two built-in pull-up resistors.
  • Compatible with open collector output encoder
  • Size:31x24mm(1.22x0.94")
  • Encoder Adapter x1
  • Cable x1
Only 8 Left
Encoder Adapter
