Technology | Advantages | Disadvantages | Positioning Accuracy | Cost |
Wi-Fi | Widely used, broad coverage | Prone to interference, lower accuracy | 5-15 meters | Medium |
Bluetooth | Low power consumption, widespread devices | Limited coverage range | 1-10 meters | Low |
RFID | Low cost, simple deployment | Requires tags, highly affected by the environment | 1-10 meters | Low |
UWB | High precision, strong anti-interference | High cost, devices not widespread | 10-30 centimeters | High |
Geomagnetic | No extra hardware needed, uses phone sensors | Susceptible to magnetic interference, lower accuracy | 1-2 meters | Low |
Figure:Wi-Fi Positioning
Advantages:
Disadvantages:
Figure: BLE and Beacon
Advantages:
Disadvantages:
Application Areas:
Advantages:
Disadvantages:
Application Areas:
Advantages:
Disadvantages:
Application Areas:
Figure: Indoor positioning
Advantages:
Disadvantages:
Application Areas:
