PROJECTS Arduino
Gesture controlled home automation
DFRobot Feb 26 2020 260919
Project Maker: saswataphysics3
Using Arduino Uno/Nano and MPU6050 module you cane easily make gesture controlled home automation.
Things used in this project
Hardware components
Arduino Nano R3 ×1
Arduino UNO & Genuino UNO × 1
DFRobot 6 DOF Sensor - MPU6050 ×1
ControlEverything.com 4-CHANNEL RELAY CONTROLLER FOR I2C × 1
Breadboard (generic) ×1
Arduino IDE
10 Pc. Jumper Wire Kit, 5 cm Long
Story
Necessary hard ware components:
1. ArduinoUNO/NANO
2.MPU6050
3.Relay module
4.Breadboard
5.Jumper wires
connections are shown in the image.
necessary library:
you can download from here
https://github.com/jrowberg/i2cdevlib to download I2Cdev library
https://github.com/ElectronicCats/mpu6050 to download mpu6050 library
software components
https://www.arduino.cc/en/Main/Software to download Arduino library
Custom parts and enclosures
Arduino Code
Upload this code
Schematics
Gesture controlled Home Automation
Controll your home appliance using gesture
Code
Gesture controlled Home Automation C/C++
Home automation
Download Code
#define SIMPLE_IMPLEMENTATION false const int frontLed = 3; const int bottomLed = 5; const int rightLed = 6; const int leftLed = 9; long int lastPrintTime; typedef struct {    byte pin;    byte positionInsideGroup;        char thePosition; // Left, Right, Up, Down    byte minAngle;    byte maxAngle;     } ledConfig; typedef struct {    byte maximumAcceptedMovement = 4;    unsigned int millisToConsiderStill = 3000;    byte firstActualAngle = 0;    unsigned long firstActualAngleMillis = 0; } axysStillness; axysStillness xAxys; ledConfig leds[] = {    {3, 1, 'u', 31, 45},      {12, 2, 'u', 16, 30},    {11, 3, 'u', 5, 15},      {5, 1, 'd', 5, 15},      {6, 2, 'd', 16, 30},    {7, 3, 'd', 31, 45},      {8 , 1, 'r', 5, 23},      {9, 2, 'r', 24, 45},    {10, 1, 'l', 5, 23},      {4, 2, 'l', 24, 45}, }; #include "I2Cdev.h" #include "MPU6050_6Axis_MotionApps20.h" #if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE    #include "Wire.h" #endif MPU6050 mpu; bool dmpReady = false;  // set true if DMP init was successful uint8_t mpuIntStatus;   // holds actual interrupt status byte from MPU uint8_t devStatus;      // return status after each device operation (0 = success, !0 = error) uint16_t packetSize;    // expected DMP packet size (default is 42 bytes) uint16_t fifoCount;     // count of all bytes currently in FIFO uint8_t fifoBuffer[64]; // FIFO storage buffer // orientation/motion vars Quaternion q;           // [w, x, y, z]         quaternion container VectorInt16 aa;         // [x, y, z]            accel sensor measurements VectorInt16 aaReal;     // [x, y, z]            gravity-free accel sensor measurements VectorInt16 aaWorld;    // [x, y, z]            world-frame accel sensor measurements VectorFloat gravity;    // [x, y, z]            gravity vector float euler[3];         // [psi, theta, phi]    Euler angle container float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector volatile bool mpuInterrupt = false;     // indicates whether MPU interrupt pin has gone high void setup() {    #if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE        Wire.begin();        TWBR = 24; // 400kHz I2C clock (200kHz if CPU is 8MHz)    #elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE        Fastwire::setup(400, true);    #endif    Serial.begin(9600);    while (!Serial); // wait for Leonardo enumeration, others continue immediately    Serial.println(F("Initializing I2C devices..."));    mpu.initialize();    Serial.println(F("Testing device connections..."));    Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));    Serial.println(F("Initializing DMP..."));    devStatus = mpu.dmpInitialize();    mpu.setXGyroOffset(220);    mpu.setYGyroOffset(76);    mpu.setZGyroOffset(-85);    mpu.setZAccelOffset(1788); // 1688 factory default for my test chip    if (devStatus == 0) {        // turn on the DMP, now that it's ready        Serial.println(F("Enabling DMP..."));        mpu.setDMPEnabled(true);        Serial.println(F("Enabling interrupt detection (Arduino external interrupt 0)..."));        attachInterrupt(0, dmpDataReady, RISING);        mpuIntStatus = mpu.getIntStatus();        Serial.println(F("DMP ready! Waiting for first interrupt..."));        dmpReady = true;        packetSize = mpu.dmpGetFIFOPacketSize();    } else {        Serial.print(F("DMP Initialization failed (code "));        Serial.print(devStatus);        Serial.println(F(")"));    }    if (SIMPLE_IMPLEMENTATION) {        initializeLEDsSimple();    } else {        initializeLEDsMultiple();    }    lastPrintTime = millis();     } void updateStillness(byte angle, bool forceReset) {    if (abs(xAxys.firstActualAngle - angle) > xAxys.maximumAcceptedMovement || forceReset) {        xAxys.firstActualAngle = angle;        xAxys.firstActualAngleMillis = millis();      } } bool isAxysStill(byte angle) {    return millis() - xAxys.firstActualAngleMillis >= xAxys.millisToConsiderStill; } void loop() {    if (!dmpReady) return;    mpuInterrupt = false;    mpuIntStatus = mpu.getIntStatus();    fifoCount = mpu.getFIFOCount();    if ((mpuIntStatus & 0x10) || fifoCount == 1024) {        mpu.resetFIFO();        Serial.println(F("FIFO overflow!"));    } else if (mpuIntStatus & 0x02) {        while (fifoCount < packetSize) {          fifoCount = mpu.getFIFOCount();        }        mpu.getFIFOBytes(fifoBuffer, packetSize);                fifoCount -= packetSize;        mpu.dmpGetQuaternion(&q, fifoBuffer);        mpu.dmpGetGravity(&gravity, &q);        mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);        int x = ypr[0] * 180/M_PI;        int y = ypr[1] * 180/M_PI;        int z = ypr[2] * 180/M_PI;        //Serial.print(y);Serial.print("\t");Serial.println(z);          updateStillness(x, false);        if (isAxysStill(x)) {            Serial.println("axys still at");            Serial.println(x);            updateStillness(x, true);        }        if (SIMPLE_IMPLEMENTATION) {                    flashLEDsSimple(x, y, z);        } else {            flashLEDsMultiple(x, y, z);        }    } } void initializeLEDsSimple() {    pinMode(frontLed, OUTPUT);    pinMode(bottomLed, OUTPUT);        pinMode(rightLed, OUTPUT);    pinMode(leftLed, OUTPUT); } void initializeLEDsMultiple() {    for (int i=0; i<10; i++) {        Serial.println(leds[i].pin);        pinMode(leds[i].pin, OUTPUT);    }    delay(3000); } void flashLEDsSimple(int x, int y, int z) {    if (y > 0) {        analogWrite(rightLed, y*4);        analogWrite(leftLed, 0);              } else {        analogWrite(leftLed, y*4*-1);              analogWrite(rightLed, 0);          }    if (z > 0) {        analogWrite(bottomLed, z*4);        analogWrite(frontLed, 0);              } else {        analogWrite(frontLed, z*4*-1);              analogWrite(bottomLed, 0);          }     } void flashLEDsMultiple(int x, int y, int z) {    for (int i=0; i<10; i++) {        //Serial.print(z);Serial.print(",");Serial.print(leds[i].thePosition);Serial.print(",");Serial.println(leds[i].minAngle);        bool modified = false;        if (z < 0 && leds[i].thePosition == 'u' && abs(z) > leds[i].minAngle) {            digitalWrite(leds[i].pin, HIGH);            modified = true;        }        if (z > 0 && leds[i].thePosition == 'd' && abs(z) > leds[i].minAngle) {            digitalWrite(leds[i].pin, HIGH);            modified = true;        }        if (y < 0 && leds[i].thePosition == 'l' && abs(y) > leds[i].minAngle) {            digitalWrite(leds[i].pin, HIGH);            modified = true;        }        if (y > 0 && leds[i].thePosition == 'r' && abs(y) > leds[i].minAngle) {            digitalWrite(leds[i].pin, HIGH);            modified = true;        }        if (!modified) {            digitalWrite(leds[i].pin, LOW);        }    } } void dmpDataReady() {    mpuInterrupt = true; }
