SELECTION GUIDE Arduino
DFRobot URM Ultrasonic Distance Sensor Selection Guide
DFRobot Apr 07 2020 268438
Product Name
Fermion: URM37 Ultrasonic Distance Sensor Breakout (2~800cm, RS232 / UART)
URM06 - Narrow Beam Ultrasonic Distance Sensor (20~1000cm, RS485)
URM06 - Narrow Beam Ultrasonic Distance Sensor (20~1000cm, UART)
URM06 - Narrow Beam Ultrasonic Distance Sensor (20~1000cm, PULSE)
URM06 - Narrow Beam Ultrasonic Distance Sensor (20~1000cm, Analog)
Fermion: URM07 - Energy-Efficient Ultrasonic Distance Sensor Breakout (20~750cm, UART)
Fermion: URM13 High Sensitivity Ultrasonic Distance Sensor Breakout (15~900cm, I2C / UART / PULSE)
URM08 - Waterproof Industrial Ultrasonic Distance Sensor (35~550cm, ModBus-RTU)
URM14 - Industrial Ultrasonic Distance Sensor with 1mm Accuracy (10~150cm, RS485)
Gravity: URM09 Ultrasonic Distance Sensor (2~500cm, I2C)
Gravity: URM09 Ultrasonic Distance Sensor (2~500cm, Analog)
Gravity: URM09 Ultrasonic Distance Sensor (2~500cm, Trig)
URM12 - Ultra Long Range Ultrasonic Distance Sensor (70~1500cm, RS485)
URM15 - 75KHZ Ultrasonic Sensor (30~500cm, RS485)
Figure
SKU
SEN0001
SEN0149
SEN0150
SEN0151
SEN0152
SEN0153
SEN0352
SEN0246
SEN0358
SEN0304
SEN0307
SEN0388
SEN0310
SEN0519
Structure
Open Divided Send and Receive
Open United Send and Receive
Closed United Send and Receive
IP Grade
NO
NO
NO
NO
NO
NO
NO
IP65
IP65
NO
NO
NO
IP65
IP65
Working Temperature
-10℃~+70℃
-10℃~+70℃
-10℃~+70℃
-10℃~+70℃
-10℃~+70℃
-10℃~+70℃
-10℃~+70℃
-10℃~+70℃
-10℃~+70℃
-10℃~+70℃
-10℃~+70℃
-10℃~+70℃
-10℃~+70℃
-10℃~+70℃
Operating Voltage
DC 3.3~5.5V
DC 6~12V
DC 6~12V
DC 6~12V
DC 6~12V
DC 3.3~5.5V
DC 3.3~5.5V
DC 6~12V
DC 7~15V
DC 3.3~5.5V
DC 3.3~5.5V
DC 3.3~5.5V
DC 9~24V
DC 5~12V
Acoustics Degree
60°
15°
15°
15°
15°
60°
60°
60°
12°
60°
60°
60°
15°
15°
Acoustics Frequency
40KHZ
50KHZ
50KHZ
50KHZ
50KHZ
40KHZ
40KHZ
40KHZ
200KHZ
40KHZ
40KHZ
40KHZ
40KHZ
75KHZ
Range
2cm~800cm
20cm~1000cm
20cm~1000cm
20cm~1000cm
20cm~1000cm
20cm~750cm
15cm~900cm
35cm~550cm
10mm~1500cm
2cm~500cm
2cm~500cm
2cm~500cm
70cm~1500cm
30cm~500cm
Resolution
1cm
1cm
1cm
1cm
1cm
1cm
1cm
1cm
0.1mm
1cm
1cm
1cm
1cm
1cm
Deviation
1%
1%
1%
1%
1%
1%
1%
1%
0.1%
1%
1%
1%
1%
1%
Communication Interface
RS232/UART/ANALOG
RS485
UART
PULSE
ANALOG
UART
UART/PULSE/I2C
RS485
RS485
I2C
ANALOG
PULSE
RS485
RS485
Multi-interface integration; Automatic gain adjustment; Automatic control of ranging;
Corrosion-resistant PVC housing; Screw-free wiring port; Narrow beam class linear directional detection;
Ultra-low power consumption; Small, streamlined design;
Small and compact body; Excellent sensitivity; Noise detection; Real-time calibration; HC-SR04 compatible; Support to expand RS485; ModBus-RTU;
High sensitivity large area detection; Full structure shielding; Real-time calibration over the operating temperature range;
High precision; Full structure shielding; Noise detection; Real-time calibration; ModBus-RTU;
High speed measurement; Configurable detection range; Professional parameter configuration; Support cascading;
Analog voltage output; Plug and play; Automatic measurement;
HC-SR04 compatible; Single signal line design;
Large reliable detection range; All-round protection design; Corrosion-resistant and anti-pollution ABS materials; Narrow beam linear directional detection; ModBus-RTU;
IP65 grade; RS485 communication interface based on standard Modbus RTU protocol; High sensitivity & small measuring angle;
Education robot omnidirectional obstacle ranging; Underground parking space monitoring;
High-voltage line-to-ground barrier avoidance; Narrow space obstacle detection;
Aircraft height; Indoor IoT Devices; Line product counting;
Collision prevention of industrial transport facilities; Unattended guards; Anti-theft alert;
Micro deformation detection; Product defect measurement; Wind speed measurement; Non-contact switch;
Robotics education; Indoor robot assisted barrier avoidance;
River water level detection; Chemical tank level detection;
Industrial controlling machines
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Since 2008, DFRobot is dedicated to provide outstanding sensor solutions to more than 200 countries and regions all over the world. And this series of products have been widely applied to various industries. Among them, the URM series of ultrasonic sensors demonstrateexcellent performance in ease of use, low-cost maintenance, quick and high accuracy measurement in multiple applications.
Until now, DFRobot own 6 categories ultrasonic sensors, as shown below:
1.URM37 Ultrasonic Sensor
Product: URM37 Ultrasonic Sensor (SKU: SEN0001)
Brief Introduction: It has rich interfaces and offers various output: analog output, switch, serial (TTL and RS232 level optional), PWM and so on. The module can be used to measure the rotation angle of the servo. Connected with an external servo, it changes into a spatial ultrasonic scanner.
2.URM06 Ultrasonic Sensor
Product:
URM06-RS485 Ultrasonic Sensor (SKU: SEN0149)
URM06-UART Ultrasonic Sensor (SKU: SEN0150)
URM06-PULSE Ultrasonic Sensor (SKU: SEN0151)
URM06-ANALOG Ultrasonic Sensor (SKU: SEN0152)
Brief Introduction: URM06 series ultrasonic sensors have very small detection angles and high detection sensitivity. They perform excellently in the target detection, especially in narrow spaces. And its integrated structure design facilitates the secondary integration and equipment assembly.
3.URM07-UART Ultrasonic Sensor
Product: URM07-UART Ultrasonic Sensor (SKU: SEN0153)
Brief Introduction: The small URM07 series are the best choices for lightweight applications. With relatively small size and concise hardware design, it is more suitable for applications that are sensitive to power consumption and quality, like micro air vehicles (MAV) and applications powered by the battery.
4.URM08-RS485 Ultrasonic Sensor
Product: URM08-RS485 Ultrasonic Sensor (SKU: SEN0246)
Brief Introduction: URM08 series ultrasonic sensors have relatively large detection angles and high detection sensitivity. It is suitable for obstacle detection and obstacle avoidance applications in the wide area, such as small transport vehicles, trolleys, forklift auxiliary barrier avoidance radar equipment. The all-metal housing is designed to maintain stable detection performance even under complex electromagnetic interference.
5.URM09-I2C Ultrasonic Sensor
Product: URM09-I2C Ultrasonic Sensor (SKU: SEN0304)
Brief Introduction: The URM09 I²C version has a customizable range/sensitivity/measurement cycle configuration that can be applied to different scenarios. The standard I²C bus communication interface can realize the connection of hundreds of sensors.
Product: URM09-ANALOG Ultrasonic Sensor (SKU: SEN0307)
Brief Introduction: The simulation version of the URM09 working operation is based on the real-time automatic ranging. It can convert the detected distance information into an analog voltage output in real time, can control the peripheral circuit solely through the output voltage, and can collect sensor data through various ADC interfaces of kinds of main controls.
6.URM12 Ultrasonic Sensor
Product: URM12 Ultrasonic Sensor (SKU: SEN0310)
Brief Introduction: The URM12 series ultrasonic sensors offer excellent all-round protection from dust and environmental pollution. Its fully shielded interior circuit design, excellent detection sensitivity and very small detection angle enable a stable directional non-contact detection in indoor or outdoor environments.
