SELECTION GUIDE LattePandaDFRobotEnglish
LattePanda Alpha & Delta Display Selection Guide
DFRobot Nov 11 2020 263814
Product Name
7 inches Touch Display for LattePanda 2 Alpha&Delta
7'' HDMI Display with Capacitive Touchscreen
10.1" 800x1280 mini-HDMI IPS Display
10.1" Diagonal - 1280x800 IPS HDMI/VGA/AV Display (Compatible with Raspberry Pi & LattePanda)
8.9" 1920x1200 IPS Touch Display (Compatible with Raspberry Pi 4B/3B+&Jetson Nano&LattePanda)
12.5" 4K IPS Touch Display (Compatible with Raspberry Pi 4B&LattePanda Alpha/Delta)
Figure
SKU
FIT0551
DFR0506
DFR0615
FIT0476
DFR0658
DFR0698
Screen Type
Display
Display
Display
Display
Display
Display
Size
7 inch
7 inch
10.1 inch
10.1 inch
8.9 inch
12.5 inch
Touch
Resolution
1024 x 600
1024x600
800x1280
1280 x 800
1920x1200
3840x2160
Brightness
220cd/m2
250cd/m^2
200cd/m2
350cd/m^2
300cd/㎡
400cd/㎡
Brand
LattePanda
Advantages
Official eDP 7inch touchscreen, perfectly compatible with Alpha and Delta. Suitable for embedded solutions
7 inch HDMI display and support touch. A very economical and practical touch screen.
The cheapest 10-inch screen. Lightweight and suitable for individual projects
The dimensions are up to most project standards and it comes with speakers to support sound output.
High definition, plug and play, and 10 touching points providing a smooth and sensitive touching experience for you.
4K IPS Touch Display supports up to 10 touch-points. Type-C ports allow UltraClear 4K UHD video display, data transfer, and SBC/mobile device charging.
Disadvantages
Only 7inch size available currently.
A little thick and bulky.
Only compatible with LattePanda Alpha, and can't work with Delta.
Include extra adapter board, which will occupy desktop space.
The size is not large enough for large screen display projects.
A little expensive and not suitable for projects with limited budgets.
Note
Can only support Lattepanda Alpha, and NOT compatible with LattePanda Delta!
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
