REVIEWS Raspberry Pi
Run phi3.5 on Raspberry Pi 5 using Ollama
DFRobot Dec 09 2024 271466
The Raspberry Pi, a pint-sized and budget-friendly Single Board Computers (SBC), has emerged as a favorite for diverse applications, ranging from educational endeavors to home entertainment systems. The launch of the Raspberry Pi 5 has markedly elevated the capabilities of this diminutive computing powerhouse, rendering it a perfect choice for handling intricate software, including SLMs(small language models) such as phi3.5 3.8b. In this write-up, we delve into the process of installing and executing phi3.5-3.8b on a Raspberry Pi 5, leveraging the Ollama runtime framework.
Overview of phi3.5
  • Parameter size: Phi-3.5-mini-instruct has about 3.82 billion parameters.
  • Design purpose: The model is designed for following instructions and supports fast reasoning tasks
  • Context support: Supports context length of 128k tokens, suitable for processing long text data.
  • Applicable scenarios: Suitable for environments with limited memory or computing resources, and can perform tasks such as code generation, mathematical problem solving, and logic-based reasoning.
  • Performance: It performs well in multi-language and multi-turn dialogue tasks, and in the RepoQA benchmark, the performance of measuring "long context code understanding" exceeds other models of similar size, such as Lama-3.1-8B-instruct and Mistral-7B-instruct.
phi3.5-3.8b-q4 has a size of 2.2GB. It is released under the MIT open-source license, which allows users to use, modify, and distribute the model freely.
Installing Ollama on Raspberry Pi 5
Ollama is a lightweight and efficient runtime framework for running LLMs on devices with limited resources, such as the Raspberry Pi. To install Ollama on a Raspberry Pi 5, follow these steps:
Install the Ollama runtime framework:
curl -fsSL https://ollama.com/install.sh | sh
Running phi3.5-3.8b-q4 on Raspberry Pi 5
Once Ollama is installed on the Raspberry Pi 5, you can run phi3.5-3.8b-q4 by executing the following command:
In verbose mode, the program will provide more output information to help developers or users understand detailed information during program operation.
sudo ollama run phi3.5:3.8b
/set verbose
This command will start the phi3.5-3.8b model and wait for input. You can then interact with the model by typing text and pressing Enter. The model will generate a response based on the input text, and the output will be displayed on the screen.
token speed of phi3.5-3.8b-q4 running on Raspberry Pi 5:3.42 tokens/s
Conclusion
Running phi3.5-3.8b on a Raspberry Pi 5 using the Ollama runtime framework is a straightforward process that can be completed in a few steps. This combination of hardware and software opens up a wide range of possibilities for natural language processing applications on a compact and affordable device. Whether you are a developer, researcher, or simply an enthusiast, the Raspberry Pi 5 and phi3.5-3.8b are powerful tools that can help you explore the world of natural language processing.
