SELECTION GUIDE DFRobotEnglish
Triple Axis Accelerometer Sensor Selection Guide
DFRobot Sep 15 2021 261937
A triple-axis accelerometer sensor is a device that measures acceleration along three perpendicular axes: X, Y, and Z. It is commonly used to detect changes in motion, tilt, or vibration in various applications.
The sensor consists of three individual accelerometers, each aligned with one of the axes (X, Y, and Z). These accelerometers measure the acceleration or change in velocity along their respective axes. By combining the measurements from all three axes, the sensor can provide a comprehensive view of the object's movement in three-dimensional space.
Triple-axis accelerometers offer a compact and cost-effective solution for measuring acceleration in multiple directions, making them versatile sensors in various industries and applications.
Product Name
Fermion: LIS2DW12 Triple Axis Accelerometer (Breakout) (±16g)
Fermion: I2C LIS331HH Triple Axis Accelerometer (Breakout) (±6g/±12g/±24g)
Fermion: I2C H3LIS200DL Triple Axis Accelerometer (Breakout) (±100g/±200g)
Gravity: I2C LIS2DW12 Triple Axis Accelerometer Sensor (±2g/±4g/±8g/±16g)
Gravity: I2C LIS331HH Triple Axis Accelerometer (±6g/±12g/±24g)
Gravity: I2C H3LIS200DL Triple Axis Accelerometer (±100g/±200g)
Figure
SKU
SEN0405
SEN0407
SEN0408
SEN0409
SEN0411
SEN0412
Type
Fermion(Breakout)
Fermion(Breakout)
Fermion(Breakout)
Gravity
Gravity
Gravity
Weight
±2g/±4g/±8g/±16g
±6g/±12g/±24g
±100g/±200g
±2g/±4g/±8g/±16g
±6g/±12g/±24g
±100g/±200g
Operating Voltage
3.3V
3.3V
3.3V
3.3V~5V
3.3V~5V
3.3V~5V
Operating Current
50nA/0.17mA
10uA/0.3~0.4mA
10uA/0.3~0.4mA
10uA/0.12mA
10uA/0.3~0.4mA
10uA/0.3~0.4mA
Communication Method
I2C/SPI
I2C/SPI
I2C/SPI
I2C
I2C
I2C
I2C Address
0x19(Default)/0x18
0x19(Default)/0x18
0x19(Default)/0x18
0x19(Default)/0x18
0x19(Default)/0x18
0x19(Default)/0x18
Dimension
15*20mm/0.59 x 0.79"
27*27mm/1.06*1.06"
27*27mm/1.06*1.06"
27*27mm/1.06*1.06"
Frequency
1.6Hz~1600Hz
0.5Hz~1KHz
0.5Hz~1KHz
0.5Hz~1KHz
0.5Hz~1KHz
0.5Hz~1KHz
Data Output
16-bit
16-bit
8-bit
16-bit
16-bit
8-bit
Difficulty (1-5)
Portrait/landscape detection; 6D/4D orientation detection; Single/double-tap recognition; Motion Detection; Wakeup for smart power saving; Self-balanced robot; Aerocraft
Free fall detection; Sudden brake detection; Rollover state detection; VR/AR; Gamepad
Impact Detection and Recording; Free fall detection; Vehicle crash test
Navigation; VR/AR; Braking detection; Gamepad
Free fall detection; Shock detection and record; Vehicle crash test
Anti-impact; High sensitivity; Communication method: I2C/SPI; Four selectable scales; Two programmable interrupts
Shockproof; Medium sensitivity; Available at high, medium or low frequency; Communication method: I2C/SPI; Three selectable scales; Two programmable interrupts
Anti-impact; Available at high, medium or low frequency; Communication method: I2C/SPI; Two selectable scales; Two programmable interrupts
Anti-impact Medium sensitivity; Available at high, medium or low frequency; I2C communicaton; Three selectable scales
Anti-impact; Wide range; Available at high, medium or low frequency; I2C communicaton; Two selectable scales
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
