NEWS DFRobotEnglish
2022 Top 10 Bestselling Products
DFRobot Jan 11 2023 264797
Thank you very much for your support and advice in 2022!
As the new year has come, we list the top 10 DFRobot Bestselling of 2022. Let's check what those tops are!
mmWave - Human Presence Detection Sensor (9 Meters)
1. Human Presence Sensing
mmWave - Human Presence Detection Sensor (9 Meters): The millimeter-wave radar sensor has the functions of human presence, human stillness, and human motion perception.
Gravity: IR Positioning Camera For Arduino
2.Position Tracking with Arduino
This is a small form factor IR camera capable of tracking up to four heat/IR sources.
The applications are plenty and can go from tracking robots with IR transmitters for navigation to light barriers, determining the direction where the object is going, and working as a flame sensor or tracking heat sources. It's fully compatible with Arduino with only four wires: two for the power supply and two for I2C.
FireBeetle ESP32 IoT Microcontroller (Supports Wi-Fi & Bluetooth)
3.Designed for IoT
FireBeetle Board - ESP32 integrates a Dual-Core ESP-WROOM-32 module, which supports MCU and Wi-Fi &Bluetooth dual-mode communication.
The electric current is just 10μA in the deep-sleep mode. The main controller supports two power supply methods: USB and 3.7V external lithium battery. And both USB and external DC can charge the Lipo battery directly.
Gravity: Huskylens - An Easy-to-use AI Camera | Vision Sensor
4.An Easy-to-use AI Camera | Vision Sensor
Gravity: Huskylens
Huskylens is an easy-to-use AI Camera | Vision Sensor.
It is equipped with multiple functions, such as face recognition, object tracking, object recognition, line tracking, color recognition, and tag(QR code) recognition.
Raspberry Pi Compute Module 4 IoT Router Carrier Board Mini
5.For Raspberry Pi Compute Module 4 IoT Router Carrier Board Mini
Compute Module 4 IoT Router Carrier Board Mini is an internet expansion board based on the Raspberry Pi Compute Module 4.
When connecting with a gigabit network card via PCle, it brings Raspberry Pi CM4 two full-speed gigabit network ports and offers better performance, lower CPU usage, and higher stability for a long time work compared with a USB network card.
Gravity: Analog pH Sensor / Meter Pro Kit V2
6.Designed to Measure the pH of the Solution
DFRobot Gravity: Analog pH meter pro-V2 is specifically designed to measure the pH of the solution and reflect the acidity or alkalinity. It is commonly used in various applications such as aquaponics, aquaculture, and environmental water testing.
Gravity: IO Expansion Shield for Arduino V7.1
7. Compatible with the Arduino Due
The DFRobot Expansion shield introduced to the market the famous color code for sensors and actuators input and output.
The 3-pin format for Signal, Voltage, and Ground is extremely useful, especially if used altogether with our increasingly large range of modules, sensors, and devices that just fit.
DFPlayer - A Mini MP3 Player
8. Low-cost mp3 Module Player
DFPlayer Mini
The DFPlayer Mini is a small and low-cost MP3 module player with a simplified output directly to the speaker.
The DFPlayer mini standalone can be used as a stand-alone module with an attached battery, speaker, and push buttons or used in combination with an Arduino UNO or any other with RX/TX capabilities.
Gravity: Analog TDS Sensor/ Meter for Arduino
9. Measuring the TDS Value of the Water
Gravity: Analog TDS Sensor/Meter for Arduino is an Arduino-compatible TDS Meter Kit for measuring the TDS value of the water, to reflect the cleanliness of the water. TDS meter can be applied to domestic water, hydroponic and other fields of water quality testing.
Solar Power Manager 5V
10. Designed for Renewable Energy Projects
Solar Power Manager 5V is a small power and high-efficiency solar power management module designed for 5V solar panel.
It features as MPPT (Maximum Power Point Tracking) function, maximizing the efficiency of the solar panel. The module can provide up to 900mA charging current to 3.7V Li battery with USB charger or solar panel.
