As Internet of Things (IoT) applications continue to evolve, developers using the ESP32 series often face challenges such as congested 2.4GHz bands, data transmission bottlenecks, and inefficient multi-device collaboration. To address these performance demands, DFRobot has introduced the FireBeetle 2 ESP32-C5 development board. This board features the latest ESP32-C5 module, equipped with dual-band Wi-Fi 6, multi-protocol support (Wi-Fi, Bluetooth Low Energy (BLE), Thread, Zigbee), and optimized power management, including a solar charging function.
Key Highlight: Dual-Band Wi-Fi 6 (2.4GHz + 5GHz) – A Breakthrough in Device Compatibility and Wi-Fi Performance
The ESP32-C5 module supports dual-band Wi-Fi 6 (IEEE 802.11ax) on both 2.4GHz and 5GHz frequencies, bringing significant network performance enhancements to IoT devices.
Key Wi-Fi 6 technologies like OFDMA (Orthogonal Frequency-Division Multiple Access), MU-MIMO (Multi-User, Multiple-Input, Multiple-Output), and TWT (Target Wake Time) further enhance network efficiency, connection density, and device power savings. This ensures stable connections and efficient data transfer even in complex network environments with many devices operating concurrently.
Other Key Features:
DFRobot has deeply optimized the power system of the FireBeetle 2 ESP32-C5 to meet the demands of diverse and harsh application environments.
The board supports power supply and program downloads via a Type-C (5V DC) interface. It also provides solder pads for an external 3.7V~4.2V lithium battery and includes an onboard PH2.0 lithium battery connector with charge/discharge management circuitry. This offers a convenient desktop development experience and allows for a seamless switch to battery power for portable or standalone applications, providing extended power support.
The FireBeetle 2 ESP32-C5 integrates a 3.3V power output pin (3V3_C) that can be controlled via GPIO 0, allowing users to manage the power state of external devices through software. By default, this pin is low (off). When an external module needs power, the control pin can be pulled high (3.3V) in the code to activate the power output. When not needed, pulling the pin low cuts the power, enabling fine-grained power management. This feature is crucial for ultra-low-power scenarios. If a project includes high-power sensors (e.g., GPS modules, gas sensors) that continue to draw power even when the system is in a low-power mode, this pin can be used to precisely control their power supply, turning them on and off as needed to minimize overall system power consumption.
Thanks to an onboard optimized Power Management Integrated Circuit (PMIC) and meticulous circuit design, the FireBeetle 2 ESP32-C5 achieves an extremely low operating current of approximately 23µA in deep sleep mode. This significantly extends the battery life of battery-powered devices and reduces maintenance costs, making it particularly suitable for prototypes of Low-Power Wide-Area Network (LPWAN) applications and long-term monitoring devices.
The board integrates a professional-grade solar charge management chip, allowing users to directly connect a 5V solar panel to charge the lithium battery. This management chip features an efficient MPPT (Maximum Power Point Tracking)-like function to optimize solar energy conversion efficiency. This feature greatly expands the application boundaries of the development board, enabling it to:
The FireBeetle 2 ESP32-C5 represents a significant upgrade over the ESP32-C6 in key network performance areas, especially with its support for the 5GHz band. This makes it an ideal choice for users pursuing more advanced applications. At the same time, it maintains full compatibility with IoT protocols like BLE, Thread, and Zigbee, offering a clear upgrade path for ESP32-C6 users seeking higher network performance.
Key Parameter Comparison:
| Key Parameter | FireBeetle 2 ESP32-C5 | FireBeetle 2 ESP32-C6 |
| Chip (RISC-V 32-bit single-core) | ESP32-C5 (240MHz) | ESP32-C6 (160MHz) |
| Memory | 384KB HP SRAM, 16KB LP SRAM, 4MB FLASH | 512KB HP SRAM, 16KB LP SRAM, 4MB FLASH |
| Wireless Protocols | 2.4 & 5 GHz Dual-Band Wi-Fi 6 (802.11ax), Bluetooth® 5 (LE), Zigbee & Thread (802.15.4) | 2.4 GHz Wi-Fi 6 (802.11ax), Bluetooth® 5 (LE), Zigbee & Thread (802.15.4) |
| Power | Type-C Supply: 5V DC, VCC Input: 5V DC or 5V Solar Panel, PH2.0 Li-ion Battery: 3.7V~4.2V, Max Charge Current: 0.5A, Supports Programmable 3.3V Power Control | Type-C Supply: 5V DC, VCC Input: 5V DC or 5V Solar Panel, PH2.0 Li-ion Battery: 3.7V~4.2V, Max Charge Current: 0.5A |
| GPIO Count | 19 (including 1 programmable 3.3V control pin, 3V3_C) | 19 |
| Peripheral Interfaces | Digital I/O x18, Programmable 3.3V Power Control x1, LED PWM Controller x6, SPI x1, UART x3 (LP UART x1), I2C x2 (LP I2C x1), I2S x1, IR Transceiver (Tx x2, Rx x2), 1x 12-bit SAR ADC (6 channels), DMA Controller (1 Rx channel, 1 Tx channel), Analog Comparator x1 | Digital I/O x19, LED PWM Controller x6, SPI x1, UART x3 (LP UART x1), I2C x2 (LP I2C x1), I2S x1, IR Transceiver (Tx x2, Rx x2), 1x 12-bit SAR ADC (7 channels), DMA Controller (3 Rx channels, 3 Tx channels) |
| Deep-sleep Power Consumption | ~23µA (on battery) | ~36µA (on battery) |
Recommended Scenarios for Upgrading from ESP32-C6 to ESP32-C5:
Upgrading to the FireBeetle 2 ESP32-C5 will bring significant improvements and expanded capabilities if your project has one or more of the following urgent needs for wireless network performance:
The FireBeetle 2 ESP32-C5 development board, empowered by the ESP32-C5 module's exceptional dual-band Wi-Fi 6 performance and multi-protocol support, combined with DFRobot's meticulously designed advanced power management system (including solar charging) and convenient expansion interfaces, offers a comprehensive and powerful development platform for IoT developers, especially advanced users with high demands for Wi-Fi performance and stability. With its outstanding dual-band Wi-Fi 6 capabilities and unique solar power management, it will help your innovative IoT projects break through performance and battery life bottlenecks.
The FireBeetle 2 ESP32-C5 is launching soon! To be the first to receive availability notifications, technical documentation, and exclusive updates, please follow our DFRobot social media accounts and subscribe to our email newsletter via the links at the bottom of this page. Don't miss out on the latest news about this powerful development board.
MPPT stands for Maximum Power Point Tracking.
In simple terms, it is an electronic technology (usually implemented with an algorithm and a DC-DC converter circuit) whose core function is to ensure a solar panel (photovoltaic module) always outputs as much electrical energy as possible under its current conditions.
To understand the need for MPPT, it's crucial to grasp two important characteristics of solar panels:
1.Non-linear Output Characteristics: The relationship between a solar panel's output voltage and current is not a simple straight line (Ohm's Law). It is described by an I-V characteristic curve. On this curve, there is a specific operating point (a combination of voltage and current) where the panel's power output is maximized. This is called the Maximum Power Point (MPP).
2.The Maximum Power Point Changes: This magical "Maximum Power Point" is not fixed. It shifts significantly with changes in light intensity, ambient temperature, and even the aging of the panel.
What happens without MPPT? (The problem with traditional PWM controllers)
Imagine your solar system simply connects the panel to a battery or the grid:
How MPPT Solves the Problem
An MPPT controller acts like a smart "energy hunter" or an "automatic transmission." It continuously performs two tasks:
1.Measure: It constantly monitors the panel's output voltage and current to calculate the current output power.
2. Adjust: Through its built-in DC-DC converter circuit (like a Buck, Boost, or Buck-Boost converter), it automatically adjusts the equivalent load impedance on the panel side (which manifests as adjusting the panel's operating voltage).
3.Seek the Peak: It uses specific algorithms (like Perturb and Observe or Incremental Conductance) to tweak the operating point, compares the power change before and after the adjustment, and determines the next direction to adjust. This process continues, allowing the system to dynamically lock onto the maximum power point for the current environmental conditions.
Significantly Increases Generation Efficiency: This is the primary goal! By always keeping the panel operating at or near its maximum power point, MPPT technology can extract 15% to 30% or even more energy compared to traditional PWM controllers. The efficiency gain is even more pronounced in low-light conditions (early morning, evening, cloudy days) and at high or low temperatures.
More Flexible System Design:
A solar panel's power output fluctuates dramatically with light and temperature, and its maximum power point is constantly changing. MPPT technology ensures that the system extracts as much energy as possible from the panel at any given moment by continuously monitoring and intelligently adjusting the panel's operating point. Without MPPT, a solar system's efficiency is severely compromised, especially in non-ideal conditions. Therefore, MPPT is an indispensable key technology in modern, high-efficiency solar power systems (whether off-grid, on-grid, or hybrid), as it directly determines how much valuable electricity you can get from the free sunlight.
