SELECTION GUIDE
How to Choose Force Sensitive Sensors (FSR) & Thin Film Pressure Sensors
DFRobot Jan 23 2026 3735
From smart wearables and robotic skins to industrial monitoring, Force Sensitive Resistors (FSR) and Thin Film Pressure Sensors are essential components for tactile feedback. DFRobot stocks a comprehensive range of force sensors from various industry-leading manufacturers. However, with so many options available in our marketplace, choosing the right one can be tricky.
This guide categorizes the sensor lineup available at DFRobot by performance, application, and budget to help you find the perfect match for your project—whether you are building a rugged industrial device or a classroom prototype.
Quick Decision Matrix: Which Sensor Do You Need?
If you need...We RecommendWhy?
High Temp / Soldering[SEN0684] Graphene SeriesWithstands 120°C & supports direct soldering.
Best Value (General)[SEN0295] RP-C18.3-LTGreat sensitivity, low cost, easy-to-access long leads.
Heavy Load (>10kg)[SEN0066] FlexiForceMeasures up to 100lbs (45kg); industrial standard.
Bed/Seat Monitoring[SEN0299] or [SEN0296]Large sensing areas (strip or square) for broad detection.
Breadboard Prototyping[SEN0047] Legacy FSRStandard 2.54mm pitch pins for solder-free testing.
Tier 1: The Game Changer (High Performance)
For professional engineers and industrial applications requiring durability.
[SEN0684] Ultra-Thin Circular Graphene Force Sensor
"A unique, solderable FSR option available in our catalog."
This is a premium addition to the store. Unlike traditional FSRs that often rely on fragile crimp connectors and melt under heat, this graphene-based sensor is designed for more demanding integrations.
Best For: Automotive (engine bays), industrial machinery, permanent installations, and high-vibration environments.
Key Advantages:
  • High-Temperature Resistance: Operates reliably from -40°C to +120°C.
  • Solder-Friendly: The unique tab material supports direct soldering, eliminating loose connections common in standard FSRs.
  • Fast Response Time: <1ms
  • Improved Repeatability: Offers better consistency compared to standard budget FSRs.
  • Specs: Range: 20g-6kg | OD: 8mm | Thickness: 0.45mm
Ultra-Thin Circular Flex Force Sensor (0.45mm, 20g-6kg Range, 120°C High-Temp Resistance)
Figure: Ultra-Thin Circular Flex Force Sensor (0.45mm, 20g-6kg Range, 120°C High-Temp Resistance)
Tier 2: The "RP Series" (Best Value & Versatility)
The Sweet Spot: High sensitivity, ultra-thin profile, and affordable pricing ($3 - $10).
Note: These sensors come in "Short Lead" (ST) and "Long Lead" (LT) versions. We generally recommend Long Leads (LT) for easier integration.
1. Button & Finger Press (Circular)
Ideal for HMI (Human-Machine Interfaces), smart buttons, and robotic fingertips.
 Front of thin film force sensor with pressure-sensitive surface and extended leads.-DFRobot product sku:SEN0295 image. Front shot of tactile sensor with peel & stick design, Thin Film Force Sensor for smart home applications. Angled shot of resistive thin film sensor surface with etched details and texture showcasing pressure-sensitive tactile design for robotics applications. Side shot showing thin film force sensor with resistive tactile design for robotics applications  Video  Photos Circular Force Sensor with Extended Leads (Diameter: 18.3mm, 20g-6kg, Thickness: 0.4mm)
Figure: Circular Force Sensor with Extended Leads (Diameter: 18.3mm, 20g-6kg, Thickness: 0.4mm)
Diameter: 7.6mm, 30g–1.5kg, Thickness: 0.3mm
Figure: Circular Force Sensor with Extended Leads (Diameter: 7.6mm, 30g-1.5kg, Thickness: 0.3mm)
2. Surface & Edge Detection (Square & Strip)
Ideal for smart furniture, medical devices, and fluid level monitoring (via clamp pressure).
Square Force Sensor (40x40mm, 20g-10kg, Thickness: 0.45mm)
Figure: Square Force Sensor (40x40mm, 20g-10kg, Thickness: 0.45mm)
Pressure Sensor Strip (400mm, 20g-10kg)
Figure: Pressure Sensor Strip (400mm, 20g-10kg)
Figure: Pressure Sensor Strip (170mm, 20g-10kg)
Tier 3: Specialty & Legacy Solutions
The Heavy Lifter: [SEN0066] FlexiForce Pressure Sensor (Ø9.53mm, 0–45kg)
  • Pros: Measures up to 45kg (100lbs), highly consistent, well-documented industrial heritage.
  • Cons: Higher cost (~$22).
  • Verdict: Use this for impact testing, weight distribution, or heavy machinery load monitoring where cheap sensors would saturate immediately.
Figure: FlexiForce Pressure Sensor (Ø9.53mm, 0–45kg, Industrial Grade)
The Classroom Classic: [SEN0065 - 4mm Mini Circular Force Sensor] & [SEN0047 - 0.5" Circular Force Sensor (100g-10kg)]
The original FSRs.
  • Pros: Breadboard Friendly. They feature sturdy 2.54mm pitch pins that plug directly into a breadboard.
  • Cons: Lower accuracy ("not for scale use"), thicker profile, and older technology compared to the RP series.
  • Verdict: Excellent for STEM education and rapid Arduino prototyping where soldering is not an option. For production, switch to the RP series or SEN0684.
Figure: 4mm Mini Circular Force Sensor
Figure: 0.5" Circular Force Sensor (100g-10kg)
FAQ: Common Questions about FSRs
Q: Can I use these sensors as a weighing scale?
A: Generally, no. FSRs are designed for qualitative force sensing (how hard am I pressing?) rather than quantitative weighing (exactly how many grams?). For precision weighing, please check the Gravity: I2C 1Kg Weight Sensor Kit in our store.
Q: How do I connect the RP Series (Tier 2) to my microcontroller?
A: The RP series uses flexible flat tails. They are not designed for soldering; direct soldering will typically damage the tail. We recommend using an FPC connector, alligator clips, or carefully crimping them.
Q: What is the difference between Static and Dynamic pressure sensing?
A: Static is a constant load (like sitting on a chair). Dynamic is a changing load (like tapping a finger). Our Graphene (SEN0684) and RP Series excel at both, with fast response times (<10ms).
Product Name
100lb FlexiForce Pressure Sensor (Diameter: 9.53mm)
Figure
SKU
SEN0684
SEN0295
SEN0298
SEN0299
SEN0066
SEN0047
Model Name
Circular Flex (Graphene)
RP-C18.3-LT
RP-C7.6-LT
RP-L-400
FlexiForce
Circular FSR
Range
20g-6kg
20g-6kg
30g-1.5kg
20g-10kg
0-45kg
100g-10kg
Size
8mm
18.3mm
7.6mm
400mm Strip
9.53mm
0.5"
Best Feature
High Temp (120°C) + Solderable
Best General Purpose (Long Legs)
Smallest Size
Best for Bed/Edge Monitoring
Heavy Duty Industrial
Breadboard Friendly Pins
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
