TUTORIALS DFRobotEnglish Tips for changing the sensor cable pin mapping
Feb 25 2013 265427
Sometimes the pin mapping of my
sensor cable is not compatible with the breakout board or IO expansion shield pin mapping. So I need to modify the cable pin mapping. Here's a simple trick to achieve this step by using one
jumper cable. Here's a simple step by step tutorial.
1. Insert the jumper cable pin to the jumper house and take the wire out of the pin house.
2. Take out two wires from the jumper house.
3. Plug in the wires to the house according the pin mapping required.
That's all. Isn't that easy? ~?~
Related Link:
Gravity Sensor
