TUTORIALS DFRobotEnglish
Tips for changing the sensor cable pin mapping
DFRobot Feb 25 2013 264645
Sometimes the pin mapping of my sensor cable is not compatible with the breakout board or IO expansion shield pin mapping. So I need to modify the cable pin mapping. Here's a simple trick to achieve this step by using one jumper cable. Here's a simple step by step tutorial.
1. Insert the jumper cable pin to the jumper house and take the wire out of the pin house.
2. Take out two wires from the jumper house.
3. Plug in the wires to the house according the pin mapping required.
cable pin mapping
That's all. Isn't that easy? ~?~
Related Link: Gravity Sensor
