SELECTION GUIDE
DFRobot Electrical Conductivity (EC) Sensor Selection Guide
DFRobot Apr 07 2026 2826
This guide provides a side-by-side comparison and selection analysis for 5 core Electrical Conductivity (EC) sensors from DFRobot, helping you quickly identify the most suitable product based on measurement range (K-value), application scenario (industrial/laboratory), and system architecture (Analog/RS485).
Product Name
Gravity: Lab Grade Analog EC / Electrical Conductivity Sensor Kit for Water Quality Monitoring (K=1)
Gravity: Lab Grade Analog EC / Electrical Conductivity Sensor for Wastewater Testing (K=10)
Gravity: Industrial Analog EC / Electrical Conductivity Meter Kit for Water Quality Monitoring (K=1, IP68)
RS485 Industrial Water Electrical Conductivity (EC) Sensor (K=1, Multi-Parameter & Pre-Calibrated)
RS485 Industrial-Grade Water Electrical Conductivity Sensor (K=10, EC / TDS / Salinity Support)
Figure
SKU
DFR0300
DFR0300-H
SEN0451
SEN0706
SEN0707
Grade
Lab Grade
Lab Grade
Industrial
Industrial
Industrial
Signal Output
Analog (0-3.4V)
Analog (0-3.2V)
Analog (0-3V)
RS485 (ModBus)
RS485 (ModBus)
Cell Constant
K=1
K=10
K=1
K=1
K=10
Measurement Range
0~20 ms/cm
10~100 ms/cm
1~2200 μs/cm
1~2000 μs/cm
10~20000 μs/cm
Temp Compensation
❌ No (External req.)
✅ Yes (Ext. PT1000)
✅ Yes (Built-in)
✅ Yes (Built-in)
Features & Core Applications
Suitable for makers/students, short-term sampling of normal water.
Suitable for short-term sampling of high-concentration liquids like seawater & brine.
Suitable for Arduino, 24/7 continuous immersion monitoring of normal water.
Top choice for Industrial IoT/PLC, long-term normal water monitoring, 4-in-1 output.
Top choice for Industrial IoT/PLC, long-term high-concentration water monitoring, 4-in-1 output.
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
(Note: 1 ms/cm = 1000 μs/cm)
Selection Decision Tree: Ask Yourself 3 Questions
Q1: What kind of water are you measuring? (Determines K-value)
  • Normal Water (Tap water, hydroponic nutrients, freshwater aquaculture): Choose K=1 probes.
  • High-Concentration Water (Seawater, wastewater, brine): Choose K=10 probes.
Q2: Will the probe be submerged in water long-term? (Determines Grade)
  • Occasional Measurement (Sampling): Choose Laboratory Grade. High cost-performance, but MUST NOT be submerged long-term, otherwise the platinum black layer will be permanently damaged.
  • 24/7 Continuous Monitoring: You MUST choose Industrial Grade. IP68 waterproof, corrosion-resistant, and supports long-term immersion.
Q3: What is your mainboard / system architecture? (Determines Signal Interface)
  • Arduino / Raspberry Pi / Maker DIY Projects: Choose Analog (Gravity) Interface. Supports 3.3V~5V wide voltage, plug-and-play, with ready-to-use code libraries.
  • PLC / Industrial Gateways / Large-scale Agricultural IoT: Choose RS485 Interface. Supports 10~30V industrial power supply, strong anti-interference, long transmission distance, and uses standard ModBus-RTU protocol.
Detailed Product Reviews & Target Audience
🟢 Maker/Lab Basic Models (Analog)
1. Gravity: Lab Grade Analog EC V2 (K=1) - DFR0300
  • Positioning: The most cost-effective entry-level freshwater measurement kit.
  • Pros: Affordable, plug-and-play, hardware-filtered stable data.
  • Cons: Limited probe lifespan (cannot be submerged long-term); lacks a temperature sensor, requires an external DS18B20 for temperature compensation.
  • Ideal For: DIY players on a budget, student projects, short-term indoor hydroponic sampling.
2. Gravity: Lab Grade Analog EC (K=10) - DFR0300-H
  • Positioning: Affordable sampling solution for seawater and high-salt wastewater.
  • Pros: Large measurement range (up to 100 ms/cm), easy single-point calibration.
  • Cons: Cannot be submerged long-term; no built-in temperature compensation.
  • Ideal For: Daily marine aquarium sampling, marine fishery water quality checks.
🔵 Maker Advanced Models: Long-Term Monitoring (Analog)
3. Gravity: Industrial Analog EC PRO (K=1) - SEN0451
  • Positioning: Top-tier hydroponic/freshwater monitoring probe compatible with the Arduino ecosystem.
  • Pros: Industrial-grade probe, truly enables 24/7 online monitoring; includes a PT1000 temperature sensor board for highly accurate temp readings; rich accessories (calibration solutions, waterproof joints, etc.).
  • Cons: The most expensive among the 5 models; larger physical footprint (uses two conversion boards).
  • Ideal For: Unattended Arduino/microcontroller projects requiring long-term monitoring, such as automated hydroponic fertilizer dispensers or ecological tank monitoring.
🔴 Professional Industrial Models: IoT & PLC Integration (RS485 / ModBus)
4. RS485 Industrial Water EC Sensor (K=1) - SEN0706
  • Positioning: The mainstream choice for modern agriculture and industrial IoT in freshwater environments.
  • Pros: Integrated design (no scattered circuit boards); 4-in-1 data output (simultaneously outputs EC, Temperature, Salinity, and TDS); factory-calibrated; industrial wide voltage (10-30V).
  • Cons: Not suitable for direct connection to a standard 5V Arduino (requires an RS485 conversion module).
  • Ideal For: Smart agriculture gateway integration, water treatment plants, commercial-scale hydroponic systems.
5. RS485 Industrial-Grade Water EC Sensor (K=10) - SEN0707
  • Positioning: The industrial-grade weapon for harsh or high-concentration water conditions.
  • Pros: Shares all the pros of SEN0706 (integrated, 4-in-1 output, IP68), while K=10 allows it to measure high-concentration liquids up to 20,000 μS/cm.
  • Cons: Also requires an RS485 supported environment.
  • Ideal For: Mariculture IoT monitoring, wastewater treatment plant online continuous monitoring.
Purchasing Recommendation Summary
If you are a regular DIY player or student doing simple tap water or basic hydroponic testing, buy the Gravity: Lab Grade Analog EC V2 (K=1) - DFR0300.
If you are building an Arduino project and the probe needs to be submerged in water forever (24/7), buy the Gravity: Industrial Analog EC PRO (K=1) - SEN0451.
If you are an enterprise user or engineer connecting to industrial gateways or PLC equipment, choose between RS485 Industrial Water EC Sensor (K=1) - SEN0706 and RS485 Industrial-Grade Water EC Sensor (K=10) - SEN0707 based on your target water concentration. Their integration, multi-parameter output, and overall cost-performance are exceptional.
