4. Once the new IoT hub options are configured, click Create. It can take a few minutes for the IoT hub to be created. To check the status, you can monitor the progress on the Startboard. Or, you can monitor your progress from the Notifications section.
5. After the IoT hub has been created successfully, open the blade of the new IoT hub, take note of the hostname URI, and click Shared access policies.
6. Select the Shared access policy called iothubowner, then copy and take note of the connection string on the right blade.
Your IoT hub is now created, and you have the connection string you need to use the iothub-explorer or the Device Explorer tool. This connection string enables applications to perform management operations on the IoT hub such as adding a new device to the IoT hub.
Manage IoT Hub
Before a device can communicate with IoT Hub, you must add details of that device to the IoT Hub device identity registry. When you add a device to your IoT Hub device identity registry, the hub generates the connection string that the device must use when it
establishes its secure connection to your hub. You can also use the device identity registry to disable a device and prevent it from connecting to your hub.
To add devices to your IoT hub and manage those devices, you can use either of:
1. The cross-platform, command-line iothub-explorer tool
2. Graphical Device Explorer tool
Use either of these tools to generate a device-specific connection string that you can copy and paste in the source code of the application running on your device. Both tools are available in this repository.
Note: While IoT Hub supports multiple authentication schemes for devices, both these tools generate a pre-shared key to use for authentication.
Note: You must have an IoT hub running in Azure before you can provision your device. The document Set up IoT Hub describes how to set up an IoT hub.
You can also use both of these tools to monitor the messages that your device sends to an IoT hub and send commands to you your devices from IoT Hub.
Use the iothub-explorer tool to provision a device
The iothub-explorer tool is a cross-platform, command-line tool (written in Node.js) for managing your devices in IoT hub. You will need to pre-install Node.js for your platform including npm package manager from nodejs.org
To install this tool in your environment, run the following command in a terminal/shell window on your machine:
npm install -g iothub-explorer
See Install fiothub-explorer
or more information.
To provision a new device:
1. Get the connection string for your IoT hub. See Set up IoT Hub for more details.
2. Run the following command to register your device with your IoT hub. When you run the command, replace <iothub-connection-string> with the IoT Hub connection string from the previous step and replace <device-name> with a name for your device such as mydevice.
iothub-explorer <iothub-connection-string> create <device-name> --connection-stringYou should see a response like this:
Created device mydevice - ... - connectionString: HostName=<hostname>;DeviceId=mydevice;SharedAccessKey=<device-key>
Copy the device connection string information for later use. The samples in this repository use connection strings in the format:
HostName=<iothub-name>.azure-devices.net;DeviceId=<device-name>;SharedAccessKey=<device-key>.
To get help on using the iothub-explorer tool to perform other tasks such as listing devices, deleting devices, and sending commands to devices, enter the following command:
iothub-explorer --help
