TUTORIALS ESP32ESP8266
ESP32 / ESP8266 Arduino: The auto keyword
DFRobot Apr 23 2018 260850
The objective of this esp32/esp8266 arduino tutorial is to explain the usage of the auto keyword when programming for the ESP8266 and ESP32 on the Arduino core. The ESP32 tests were performed using a DFRobot’s ESP32 module device integrated in a ESP32 development board.
The objective of this post is to explain the usage of the auto keyword when programming for the ESP8266 and ESP32, on the Arduino core.
The auto keyword, which was introduced in the C++11 standard [1], allows to remove the explicit type declaration of a variable.
So, instead of specifying the type of the variable before its name, we use the auto keyword and then, when the code is compiled, the compiler will infer the correct data type for us.
Note that the auto keyword can be used for local and global variables but not for class members or function parameter definitions [1]. For a deeper analysis on the auto keyword, this article provides a great explanation.
Please not that this is a C++ concept and thus you can apply it when programming in this language, even if your target platform is not a microcontroller. Furthermore, this program should work when programming for other boards (such as the ones in the Arduino family), when using the Arduino environment.
The code
For this example, we will start by declaring a very simple class, that we will use to confirm that the auto keyword can be applied for inferring the type of an object of that class.
For an introduction on how to create a class, please consult the previous post. Note that this class is slightly more complex since we added it a constructor, for initializing the data member.
class TestClass{
  public:
    int x;
    TestClass(int arg1){
      x = arg1;
Next we will declare a function, also to confirm that we can use the auto keyword for the compiler to infer the return type of a function, to be able to assign its value to a variable. Our function is very simple and will take no arguments and return an integer.
int testFunction(){
  return 10;
Moving on to the Arduino setup function, we will start by opening a serial connection, to later print the results. We will then instantiate an object of the previously declared class, but using the auto keyword instead of specifying the class as type.
Serial.begin(115200);
auto myObject = TestClass(10);
Next we will call our function and assign the returning value to a variable, again using the auto keyword.
auto functionResult = testFunction();
After that, we will just declare a variable of a basic type (int) also using the auto keyword.
auto myInt = 20;
To finalize, we will print the values of all variables to the serial console, to check that everything was correctly assigned. You can check the full source code below.
class TestClass{
  public:
    int x;
      x = arg1;
int testFunction(){
  return 10;
void setup() {
  auto myInt = 20;
  Serial.print("Object data member: ");
  Serial.println(myObject.x);
  Serial.print("Function result: ");
  Serial.println(functionResult);
  Serial.print("Int variable: ");
  Serial.println(myInt);
void loop() {}
Testing the code
To test the code, simply compile it and upload it to your ESP device. Note that if the code throws no compilation errors, it means that no error was detected in compile time, due to the introduction of the auto keyword.
If we open the serial monitor, a result such as the one shown in figure 1 should be printed, indicating the correct behavior of our program.
Figure 1 – Output of the program, using the auto keyword.
As expected, we were able to access the value of our class data member, of the output of the function and of the integer variable.
