New Topic
Register
Login
HOME
COMMUNITY
FORUM
WIKI
BLOG
LEARN
Tags
Suggestions
How to select
Troubleshooting
General
UNIHIKER
3D Printing
PCB Services
Bluno
uPyCraft
Mind+
Easy IoT
Telematics
Robotics
Firebeetle ESP32/8266
Raspberry Pi
HUSKYLENS
Gravity
LattePanda
Arduino
314
Views
1
Replies
Hi,After installing the sensor and connected to 5V, the longest distance I can adjust is 60cm, not 400cm. I have tried 30, 50, 60, 100 and 200 cm, but the maximun distance that det...
SEN0531
Tonny12138
2023-09-22 23:04:57
1
Gamepad v2.0 and xbee
2
How to open the adapter-Solved
3
Serial 7-Segment Display with OBD-II UART
4
Re: Arduino OBD-II UART adapter questions and inquries
5
NB-IOT SIM7000 Arduino Shield TurnOn Problem
6
missing MaQueen Plus in Mind+ Kit choices
7
DFRobot-MaqueenPlus.h
