I2C scanner finds sensor but sample code fails to initialize SEN0359FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:28 3298 Views
Unable to Initialise Gravity: Capacitive Fingerprint Sensor [SEN0359] via ESP32 FAQSEN0359SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:02 3189 Views
Unable to Program Light Rings in Mind+? [Gravity: Capacitive Fingerprint Sensor SEN0359] FAQSEN0359SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:02 420 Views
I was able to scan the sensor address using the I2C scanner, but unable to initialise the sensor after uploading the sample code. SEN0359FAQAftersales FAQ
Yx 2024-07-12 15:04:05 Trending
- 4 Firebeetle ESP32 read battery voltage
- 9 Beetle ESP32-C6 Serial Monitor not working
- 10 text section exceeds available space in board
