Newbie - need help with Motor Driver
Account cancelled 2012-06-13 22:49:21 5630 Views1 Replies i bought a 1amp motor sheild for arduino and a miniQ robot chasis to make a 2wd robot. i have a netduino. i've put the parts together, but i can't get power to the wheels.
1) do i have to use external power to turn the wheels? or can i use the power supplied to the netduino?
2) if i have to attach extra power, do i just solder to GND and VIN on the motor sheild pwr in?
3) will attaching a 9v battery connector be sufficient?
thanks! tom
thanks! tom
2012-06-19 19:49:59 Hi Tom,
Sorry for the delay in responding.
How are you providing power now?
If you are only providing power to the Netduino now, what are you using? I would recommend to use an external power supply like a DC wall adapter to provide about 7-9Vdc to test, if you can get movement like this then you know its a power issue. Sometimes USB cables will not provide enough power.
If you solder 2 pins to the PWR IN section, this would provide power to the motors AND the Netduino.
*THIS IS VERY IMPORTANT!!*
Be very careful not to connect the Netduino to the USB while the battery is connected to the shield.
You can see the schematic for the shield:[url=https://www.dfrobot.com/wiki/images/3/31/Arduino_Motor_SCH.png] Here[/url]
The 9V batter will provide enough power, but I'm afraid it wouldn't last very long. If you want a long lasting battery, I recommend a LiPo battery like the one we sell.
[url=https://www.dfrobot.com/index.php?route=product/product&filter_name=lipo&product_id=489]7.4Vdc LiPo Battery[/url]
Hector
Hector
