DFRobot romeo V2 mini usb connection
Account cancelled 2014-01-03 03:27:00 7332 Views4 Replies I've just bought a romeo V2 and I'm disappointed by the poor quality of micro usb connector.
It disassembles from the board after two connections with our micro usb cable and we are now facing no possibility to download our code from the PC.
I would like to highlight the point that CMS micro usb plug seems to be an unreliable solution for this type of use.
I would rather prefer the ''old'' A-B usb connector of previous card version.
Another solution would be to provide an USB =>micro usb adaptor cable that could be held on the robot structure by mechanical means or glue.
Do you know if it's possible to download programs to the romeo using the provided Xbee socket? Do we need another shield to communicate with the PC?
Or is it possible to use blue-tooth, what kind of additional shield/hardware is needed to communicate with th pC?
I wish everybody a happy new year
2014-01-08 22:56:06 If you have interest in fixing it by yourself.
We will provide a way to help you.
The solder is not so bad as you think.
(What should be attention is that the solder can't be inside.)
Grey.CC
Grey.CC 2014-01-08 22:48:34 Hello Jean and demastri
Sorry?I have test all wireless programming module.
The Leonardo doesn't support program from the serial port.
And part of products appear this issue, and we will fix it
Please contact with our tech-support mail: [email protected]
We will give a reply as soon as possible
Grey.CC
Grey.CC 2014-01-08 12:12:49 Actually, I have the same problem. USB connector came straight off the board.
I can solder, but these are surface mount traces, I don't think I could do that easily (unless you have other points on the board they're available.
Please help with either:
1 - the original poster's first question - is there a way to program the board using the other serial port on D0/1 or by APC220 module?
2 - if there's a way to reconnect the USB connection that's easier than dealing with surface mount components, please let me know.
3 - We've had the board about 2 weeks, you mentioned that you'd try to help fix it - let me know what my options are for that.
Thanks!!
demastri
Thanks!!
demastri 2014-01-03 22:03:39 Hello Jean?
Sorry?we have found this this issue. The usb port will often drop down.
Do you have an electric soldering iron and soldering tin?
Now we get an idea to use solder to fix this issue.
If you haven't ,you could send it to us. And we will help you to fix it .
Grey.CC
Grey.CC
