DFR0140 overvoltage?!
Account cancelled 2015-03-29 21:01:14 5934 Views1 Replies My DFR0140 is passing the input voltage straight through to the nominal 5V output pins. I've been powering it from a 9+V power supply, resulting in overvoltage on downstream components that expect 5V.
Any ideas what might have happened to the voltage regulator? Is this something I did, or a defective part?
Thanks!
Thanks!
2016-02-15 23:37:42 Hi David,
How are you!
Momentary over-voltage on the components may makes hot, if it was kept on, then it will be burnt out.
Leff
How are you!
Leff
