LCD Keypad Shield V1 Pinout?
userHead anthony_irwin 2015-04-09 16:03:40 2885 Views2 Replies
I picked up the V1 of the LCD keypad shield DFR009/1602KPS but the pins dont seem to corrispond to the wiki.
For the new version it shows pins on the top right of the board that should be D13- D0, GND, VCC, but those same pins aren't labelled in the wiki for V1.
I have a project that uses D13 and it won't work if I use the pins shown in the wiki, so does anyone know the proper pinout so I can use D13, or any of the digital pins.
2015-04-10 20:00:58 Hi,
:D
It works fine_the GND, believe me! the pin on the pin are not directively connected to the pin below the pcb borad, you can check the schematics.
userHeadPic Leff
2015-04-10 03:10:36 Yes I saw that, but that's not what my board looks like. However I think D13 works, but GND(in the red circle) doesn't appear to pass through to the shield I have.
EDIT
Ya, I only have 7 pins on my shield in that location.
userHeadPic anthony_irwin
