sim908
antik 2014-02-19 13:25:10 4647 Views6 Replies i buy http://www.dfrobot.com/wiki/index.php/G ... TEL0051).i add sim card e not show gsm led status oly power led please how to install product
2014-02-21 18:01:16 Hello, antik
The GSM module need to be set the parameter before you begin to use it.
Or you also could try it with the sample code
What is your sketch you are using now?
The sample code?
Grey.CC
The sample code?
Grey.CC 2014-02-21 04:06:06 my modem work power suply 7-12v i connect power syply in gnd and vin show only power led .i conect power suply 5v in 5v pin and gnd show only led power ,not show led net stat.please how to activate gsm network.
antik
antik 2014-02-20 18:12:53 Hello antik,
Oh, the GSM module can't work without the sketch. you could follow the wiki page and set it step by step.
If you have any question, you could ask them here.
Anyway, your power supply is too strong. Although it could works now , it will heat up and kill the circuit in the long run.
Grey.CC
Grey.CC 2014-02-20 00:37:01 I use external power 12v 2a not use comand first installation no net status light only light power
antik
antik 2014-02-19 18:08:51 Hello antik,
Did you use an external power?
And which code you are using now?
Could you attach your hardware connection here?
Grey.CC
Grey.CC
