Trouble Shooting_Veyron DC motor driver DRI0021/DRI0020
Leff 2015-08-11 20:09:19 6912 Views1 Replies If you find nothing about your question, please add reviews about yours. Thanks!
Equipment:
1. Veyron driver broken?
Wiring:
Operation:
Just thrust the KEY to switch to Set mode, wait a seconds, two motors will run. Then prove the Veyron driver is ok.
2. Veyron Serial communication not work?
Operation:
Download the library first and install the library, the sample sketch is in the library.
Note: It's different from the one from the wiki page.(Serial instead of Serial1; set higher speed at 200rpm)
2 Upload sketch “B_CheckSerial”.
Note: when you are going to upload anything, please unplug the wire on the PIN 0,1.
Open the Serial monitor, choose "57600".
If you do not see it, reverse the tx&rx sequence and check again.
3 Upload sketch “C_RunMotor”.
Then you will see your two motors running according to the sketch.
Leff
