Smart Servo Shield on Arduino Mega
userHead Phase83 2014-03-24 19:57:13 4365 Views3 Replies
I was wondering if it is possible to use the Smart Servo Shield on an Arduino Mega 2560? I have attempted to upload the example code but, I can only get responses using an Arduino Uno. I believe it probably has something to the with the #include_arduino.h. I was hoping I could obtain an example of the Smart Servo Shield controlling AX-12 Servos on an Arduino Mega. Any help will be much appreciated.
2014-10-08 03:37:27 Mhh me too , i have the same problem..
But yesterday i bought and tried with a UNO and still not work.
Can you please check this forum, post : http://forum.arduino.cc/index.php?topic=269159.0
and tell me if i plug correctly ?
It's will be so nice if i can understand. :'(
Many thanks in advance
userHeadPic middle
2014-03-25 20:06:57 I connect the AX-12A servos directly to the shield as is described in the wiki. The shield is then connected directly to the Arduino Mega. I powered the Arduino and the  Smart Servo Shield off of a 9.6V power supply connected to the shield's Vin and GND pins as the Smart Servo Shield wiki suggested. I believe the "arduino_pins.h" that is included in the sample sketch is specific to the UNO. I was hoping that another sample sketch could be uploaded that would do the same actions as the sketch just for an Arduino Mega.
userHeadPic Phase83
2014-03-25 19:52:02 Hello Phase,
How do you connect the smart servo?
Here is a wiki about the mega connection diagram.
https://www.dfrobot.com/wiki/index.php/H ... KU:SER0032
Maybe it could help you~
userHeadPic Grey.CC
