X-Board V2 + serial to ESP8266 Not Working
albertusgeyser 2015-11-10 23:28:53 3082 Views3 Replies X-Board V2
http://www.dfrobot.com/index.php?route= ... kGZb78ppK8
WiFi Serial Transceiver Module Breakout Board w/ ESP8266
http://netram.dfrobot.za/2217-wifi-serial-tr ... p8266.html
I used pins 0-(Rx) and 1-(Tx) on Arduino Uno at bautrate (9600) with 100% success, BUT
If i use X-Board V2 with same sketch (no changes) on pins RX and TX at bautrate (9600) then it fails to work.
What am i doing wrong or what could be cause of failure?
Hope anyone can help me.
Thank You
Albertus Geyser
2015-11-12 04:27:34 Good Day
I have no problem loading sketch to X-Board v2 (Atmel 328), my problem is that ESP8266 Wifi module does not want to communicate to X-Board v2 as it does to Arduino UNO.
I use RX and TX on X-Board V2 and 0 - RX and 1 - TX on Arduino UNO on UNO it works, but on X-Board V2 not.
I am using following on both:
Serial.begin(9600);
Serial.setTimeout(5000);
What could be issue with Serial on X-Board V2?
Thank You
Albertus Geyser
albertusgeyser
Serial.begin(9600);
Thank You
Albertus Geyser
albertusgeyser 2015-11-11 18:19:55 Hello Albertus,
Welcome!
I think it should be no problm with the same sketch used on Uno if you have uploaded the sketch to the 328P chip successfully!
can you upload a simple sketch to light up a led?
Welcome!
Leff
