Looking for example sketch for SD operation for DFRobot W550
userHead dyrex 2015-11-22 01:11:51 1958 Views1 Replies
I'm looking for sketch examples how to use SD card in DFRobot DFR0342 ( http://www.dfrobot.com/index.php?route=product/product&product_id=1286&search=0342&description=true#.VlA1aHYvdD9).
I tried to use example (e.g CardInfo) from Arduino IDE but it does not work. I've got
"Initializing SD card...initialization failed."
I thing that maybe examples use improper port for SPI - example use (at least in comment is such info)
MOSI - pin 11 , MISO - pin 12 ,vCLK - pin 13 but there is no information how to change it or maybe it change automaticly when proper Arduino board is selected ?
Regards
Michał
2015-11-23 23:41:35 hi Michal,
Welcome!
I also want to use the SD module on W5200 shield~ How is it going? Did it solved so far?
userHeadPic Leff
